Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Groups & Staffs › Child Theme views not working
- This topic has 3 replies, 2 voices, and was last updated 6 years, 5 months ago by
Ramamurthy Krishnan.
- March 16, 2020 at 10:32 am #111758
Tony Rumans
Participantwcfmgs-view-managers-manage.php
I’ve placed that file with my edits in my theme/wcfm/views directory and it’s not overriding wc-frontend-manager-groups-staffs/views/wcfmgs-view-managers-manage.php
Is that the correct path for my child theme?
- March 19, 2020 at 10:54 pm #112303
Ramamurthy Krishnan
You can’t override the file like this.
Can you please specify your requirement so that I can tell you another way out?Thanks,
- March 19, 2020 at 10:58 pm #112304
Tony Rumans
ParticipantI’m trying to comment out the section of code attached
I first tried using a filter but I don’t see how it can be done.
You must be logged in to view attached files. - March 21, 2020 at 12:19 am #112460
Ramamurthy Krishnan
The screenshot of the code you shared seems that you want to remove the header portion of store manager. It will remove the notification, inquiry, etc. (screenshot attached below) options also.
Do you want this?
If yes then please add the below code to your theme’s style.css file.PFA….
- The topic ‘Child Theme views not working’ is closed to new replies.
