Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Commission : calculation and tax
- This topic has 3 replies, 2 voices, and was last updated 6 years, 11 months ago by
- October 2, 2018 at 12:19 pm #33043
Vinz
ParticipantHi WC LOVERS,
I have some requests about the Commission system :
1/ Currently, Commission are calculated on the product price without tax. Is it possible to calculate it on the price tax included?
2/ Is it possible to add the possibility to set tax on the commission? Because currently, the commission is without tax. In my case, I have to bill a commission with tax included to the vendor!
Thanks !
- October 2, 2018 at 4:51 pm #33065
1. Tax – you may set whether Tax is going to vendor or not! Are you looking for something else?
2. Commission Tax – I think you want to deduct this from vendor’s commission, right? Just set withdrawal charge accordingly.
- October 2, 2018 at 5:49 pm #33068
Vinz
Thanks for your answer:
“1. Tax – you may set whether Tax is going to vendor or not! Are you looking for something else?”
Ok I understand, so I will increase my commission rate to match with the “tax included” amount.
I understand your solution, but my problem is that the rate of my commission/withdrawal depends of the product and vendor. And it seems to be setup once, right? So, the best way to me, would be to have the possibility to set up the withdrawal rate product by product or vendor by vendor.
Do you think it’s possible for you to make this kind of feature? 🙂Thanks!
- October 3, 2018 at 3:51 am #33118
I understand.
Well, you may off course set different withdrawal charges for vendors right now.
But product specific is not yet there. Actually, it’s depend upon total withdrawal amount and not for a particular order so we didn’t add this at product level.I will look for a better solution for you.
- The topic ‘Commission : calculation and tax’ is closed to new replies.
