Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Commission not been calculated correctly after price modifications
- This topic has 14 replies, 3 voices, and was last updated 6 years, 5 months ago by
digitalcinemacrew.
- March 26, 2019 at 6:47 pm #54640
digitalcinemacrew
I’m using WCFM Ultimate and WC Marketplace. After submitting an order, if the vendors or the administrators change the price of a specific product in pending payment, when the order is payed and goes on processing, the commission for vendor on that product is calculated on the original price and not on modified price. Is it normal? Can it be calculated on modified price somehow?Thanks.
- March 28, 2019 at 10:55 am #54924
Which multivendor plugin you are using ?
WC Marketplace or WCFM Marketplace !
- March 28, 2019 at 11:05 am #54929
digitalcinemacrew
I am using WCFM Marketplace. - March 28, 2019 at 2:14 pm #55004
MemberOK, how you are changing price?
If from wp-admin orders then it will change vendor’s commission.
Edit order from WCFM Orders and apply discount to change order total – https://ibb.co/D43NG2k
Vendor commission will be updated as well!
- March 28, 2019 at 2:21 pm #55006
digitalcinemacrew
yes, I’m changing it from wp-admin orders and the commission for vendor calculated in withdrawal request is not changing. When I accept and pay vendor’s payment, it calculates commission on original price… So something is not working properly!Ex. original price is 100€ – commission for vendor is 90% = 90€ commission – If I change price from 100€ to 90€, commission for vendor stays 90€ instead of 81€
- March 28, 2019 at 2:34 pm #55009
digitalcinemacrew
ParticipantThis is how I set commission (see attach)
You must be logged in to view attached files. - March 29, 2019 at 9:46 am #55158
MemberOK, that’s fine!
- March 29, 2019 at 9:52 am #55160
digitalcinemacrew
ParticipantYes, but commissions are still not calculaed properly if I change the price. It always calculates on original price and not on discounted.
Can you double check please?Thanks
- March 29, 2019 at 11:49 am #55174
Jose
I did the same exercise to try and work perfectly.
The commission setting after discount is for discount coupons. It is not your case
If you change the original price after the purchase, you can not change the original price. The customer bought at the original price. If it would not be a fraud.
If another customer makes a purchase after the changes, you will see the new price. And the commission will be made regarding the new price.
Regards,
- March 29, 2019 at 12:17 pm #55182
digitalcinemacrew
I better explain my case to understand if something is wrong or not:I use Woocommerce Bookings for bookable products and, before any payment, vendors can approve or not the orders received from customers. So, every order made by a customer cannot be payed until the vendor approve it and the order goes on Pending Payment. In this situation, vendor can decide to apply a discount on that order before the customer pays for it (ex. from 100€ to 90€). Admin manually modifies the price for that order in wp-admin orders, vendor approves the order and the customer pays for that order with modified price. But, when the order status changes from Pending to Processing (payed order) the commissions for vendor is calculated on the price before the modification, while it should be calculated on final price…
Does it work like this on your hand? Is there a way to let it work like I expect?Thanks
- March 29, 2019 at 12:29 pm #55183
Jose
I understand all.
You said that in woocommerce order admin, but here we are in wcfm. That’s the problem.
I know but wcfm don’t have this feature, so will be great if wcfm make this for us. Make a discount not up the price 😉
The same happend with refunded, if you use refund by wc admin, the vendor and customer don’t understand nothing.Regards,
- March 29, 2019 at 12:33 pm #55184
digitalcinemacrew
ParticipantSo how can I make discount from WCFM (Admin or Vendors) to let this work as I expect?
It would be better for Admin to use only WCFM instead of wp-admin screen…Thanks
- March 29, 2019 at 12:50 pm #55186
Jose
ParticipantYou can not right now, just wait for a response from wcfm keymaster!
For me it was difficult to understand this, but it is different that you can see the admin vs. what the seller sees in an order.
The administrator can see everything he did in the woocommerce order, but the vendor order view is a new screen that was made for this multi-market system, so they need to add code to reflect it.
Regards,
- March 29, 2019 at 3:47 pm #55210
Jose
ParticipantUse WooCommerce Bulk Discount Its a plugin that have compatibility with WCFM.
https://wordpress.org/plugins/woocommerce-bulk-discount/
Regards,
- March 29, 2019 at 4:01 pm #55213
digitalcinemacrew
ParticipantHi Jose,
thanks for your link, but actually I need to generate discounts for each order once it has been placed for approval from vendor. I already have discounts based on number of days and so on. I mean a Customer places an order and asks for a discount, then Vendor decides if a discount can be applied on that order and approves it for payment. Finally the customer can pay for that discounted order and commissions for vendor are calculated on that discounted price. All is working fine for me but not the commissions calculated on discounted orders. They should be regenerated when Vendor/Admin modifies prices before Customers pay for orders.
- The topic ‘Commission not been calculated correctly after price modifications’ is closed to new replies.
