Black Friday
04Day 12Hr 46Min 32Sec
Black Friday
Commission per vendor in the same Cart
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Commission per vendor in the same Cart
Viewing 1 reply thread
    • #126745
      Yvo
      Hi there,
      I’ve just put on 3D Secure with Stripe Split Payement, I’ve just updated commissions in oder to adjust commissions per vendor.
      Here is what I did :
      Order : 5€ or less
      Fixed : 0,10 €
      Commission : 6%
      Order : More than 5€
      Fixed : 0,30 €
      Commission : 2%
      In the same cart I have :
      Product A (from Vendor A) : 2 €
      Product B (from Vendor B) : 15 €
      Commissions for Vendor B are OK : 0,30 + 0,30 € (15×2%) = 0,60 €
      Commissions for Vendor A are NOT OK : 0,30 € + 0,04 € (2×2%) = 0,34 €… While I was waiting for : 0,10 + 0,12 (3×6%) = 0,22€
      So, what I’ve understood is that the commission rule applied was due to the global cart amount and not the Vendor Global Amount in the Cart… Is there any way to apply a rule depending on the Global Vendor Amount for each order ?
      Regards,
      Yvo
    • #126793
      ciccupio97
      Follow
  • The topic ‘Commission per vendor in the same Cart’ is closed to new replies.
