Conflict (?) – can't publish a product with picture
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Conflict (?) – can't publish a product with picture
Viewing 3 reply threads
    • #30858
      acbardou
      Hi !
      Thanks for your great work. Still, I have great troubles publishing a product from the wcfm plugin with a picture. When uploading the picture, I’ll get an error and then an “undefined” when trying to create the product – even without any picture-.
      I read in one of your threads that there were troubles with WP user avatar, so I deleted it and installed avatar manager instead. It all worked like a charm for… a few hours.
      And we are back to error.
      Can you please look into this ? Thank you !
    • #30868
      Thanks for get in touch with us and really sorry for the trouble.
      First of all, this is not all related to WP User Avatar.
      I assume this is due to some other plugin.
      If you are comfortable then please share your site details so that we can debug this – https://wclovers.com/contact-us/
    • #30893
      acbardou
      thanks for your answer. I figured a few things myself. It seems that when a vendor logs in via the home page (and the login widget) and then goes to his dashboard, he will NOT be able to post the picture of a product.
      However, when he logs in via the “my account” page, THEN he gets to post the picture.
      This is reassuring in a certain way because it shows that publishing a product and a picture is possible. But it would be really easier for the vendors if you could solve this (and my life).
      I posted this message to inform the others using WCFM and I’m sending you my site details in private.
      Thank you !
    • #30951
      Please send me site details and I will take a look at it.
      Please know me one more thing, which plugin you are using for setting homepage login widget?
      Send me site details from here, then I will have those in my inbox – https://wclovers.com/contact-us/
  • The topic ‘Conflict (?) – can't publish a product with picture’ is closed to new replies.
