Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › connect vendors to STRIPE
- This topic has 3 replies, 2 voices, and was last updated 6 years, 2 months ago by
Gregorio.
- April 28, 2020 at 10:24 pm #124383
Gregorio
we are trying to let our vendors to connect their accounts on our market, made with wcfm with ultimate, to stripe, but we have a problem: we want to let them connect with standard connect account, but the link of the “connect with stripe” button refers to an EXPRESS account instead of a STANDARD account that’s the one I need for those vendors who have a Stripe account already.Can you help us to understand how to customize the button link?
Thank you,
Gregorio - April 29, 2020 at 6:04 pm #124663
paul-8288
ParticipantYes, I have this same problem been going backwards and forwards with stripe, when it turns out that the oauth link creates the express account.
- April 29, 2020 at 6:18 pm #124666
paul-8288
ParticipantI have been having a play around, adding this to my Themes functions.php file seems to do the trick, looking at past topics it appears that it is now defaulting to express rather than standard.
add_filter( 'wcfm_is_allow_stripe_express_api', '__return_false' ); - April 29, 2020 at 9:23 pm #124737
Gregorio
ParticipantThank you for the suggestion: the workaround works! I did the same in the code of the plugin before, but wasn’t working yet. That’s easy and it works! Also, to avoid to loose it in some wp’s update, I used a php snippet to activate the filter.
For the moment it’s a working solution, but I think should be fixed in a next release of wcfm.
- The topic ‘connect vendors to STRIPE’ is closed to new replies.
