Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Crop, Rotate, Scale, or Flip Images
- This topic has 10 replies, 4 voices, and was last updated 5 years, 10 months ago by
- February 11, 2019 at 3:21 pm #47729
Brian
I need the option for my vendors to Crop, Rotate, Scale, or Flip there product images. How is this possible?
Im running WCFM as frontend for vendors and vendors don’t have access to wordpress backend.(Backend is set to off) - February 12, 2019 at 6:09 am #47812
Well, WP backed Image editor will not work for frontend.
We have a plan to use another image editor for frontend.
- February 14, 2019 at 7:09 pm #48272
Venu v
GuestWhen it will be integrated sir/madam
- March 3, 2019 at 6:25 pm #50982
Craig
ParticipantThis will be a great feature. Especially for the shop header and logo so the vendor can easily crop the image to fit properly.
Would this plugin work? https://wordpress.org/plugins/aviary-editor/
This particular plugin does not look like it has been updated in some time. - March 4, 2019 at 5:10 am #51025
It’s a out-dated plugin.
- March 21, 2019 at 10:07 pm #53891
Craig
ParticipantI vote for this feature. It will be welcomed by the vendors.
- March 22, 2019 at 2:15 pm #54018
Michel Carriere
I vote for this feature too.
- June 5, 2019 at 3:15 am #65947
Craig
ParticipantHi there,
In a previous reply above you indicated that “We have a plan to use another image editor for frontend”. Do you have an estimated time line for that integration?
Many thanks
Craig - June 5, 2019 at 6:59 pm #66083
MemberHopefully it will be there by end of this month.
- June 6, 2019 at 8:44 pm #66290
Craig
Participantawesome thanks!
- May 12, 2020 at 5:45 pm #130029
MemberIt’s supported. https://www.loom.com/share/abb359a4a3b74f8c8b8c69243401145c
- The topic ‘Crop, Rotate, Scale, or Flip Images’ is closed to new replies.
