Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › CSV import blogged by wordfence
- This topic has 5 replies, 2 voices, and was last updated 6 years, 4 months ago by
sdel_nevo.
- July 22, 2019 at 7:55 pm #73480
CommunityCorals
I just tried to upload a csv file from frontend and got a 403 block from wordfence. Any idea how to whiteliste this action?
BR
Dominique - July 22, 2019 at 8:46 pm #73483
sdel_nevo
try putting wordfence into learning mode and try again
to do this go to
wordfence – firewall
Click on “Manage WAF” under “Web Application Firewall”on the dropdown in Web Application firewall Status, select “learning Mode”
try the action again
if is successful without any wordfence issues follow the procedure again, but this time select “Enabled and protecting”
Wordfence should have learnt that this is safe
Steve
- July 22, 2019 at 9:07 pm #73486
CommunityCorals
ParticipantHey Steve, thank you very much. That helped !
BR
Dominique - July 22, 2019 at 9:11 pm #73487
sdel_nevo
ParticipantHi mate
Your most welcome
That caught me out too
Steve
- July 23, 2019 at 12:09 pm #73568
CommunityCorals
ParticipantHm now the upload starts but nothing happens. In Wordfence learning mode I get a progress bar until 70% in protect modus no progress at all.
Anyone a recommendation?
- July 23, 2019 at 12:12 pm #73569
sdel_nevo
ParticipantHi mate
I find that the upload extremely slow, that being said I have vendors who used it to upload 2000+ products but this took ages
during testing, I had to get in touch with my host, and they increased some of the time out values
the big one that needed to change was the max_input_vars this has been set at 8000 and works without error, but it is very slow
Steve
