Diwali
04Day 22Hr 04Min 01Sec
Diwali
Custom commission scheme based on WC Bookings block costs
Viewing 12 reply threads
    • #40441
      Pradeep M
      Hello there,
      Could someone kindly give me some directions on how to set up a vendor commission scheme based on WooCommerce Bookings’ block costs? I have a client who wants a site set up where the vendors get a percentage of the total of block cost as their commission. I would assume the logic would be:
      – get product details and booking duration for each product
      – calculate the total of block costs for each product
      – assign the percentage, for example 70%, of those totals to respective vendors
      I can find my way around the first two steps. It would be great if someone can show me how to put everything together so vendor commissions get updated every time a customer places an order.
      Many thanks in advance!
    • #40468
      I am a bit confused with your query.
      Hope you have already set commission 70%
      Now setup a booking product.
      When customer will book that product 70% commission will be generated for vendor.
      Why you require custom setup?
      • #40806
        Pradeep M
        Hello again,
        Sorry it seems I have not explained it properly. What I need to do is give the vendors only a percentage of the total of “block cost” amount. Let’s say if the base cost is 400 and the block cost is 500. If the product total for a booking is 900, they will get 500 * 0.7 = 350. If the total is 1400, they will get 1000 * 0.7 = 700.
        Here’s the code I’ve written for WooCommerce Product Vendors. It would be great if you could help me to get this to work with WCMV Marketplace.
        //Calculate and add commissions
        add_action(‘woocommerce_thankyou’, ‘mysite_woocommerce_order_status_completed’, 10, 2);
        function mysite_woocommerce_order_status_completed( $order_id) {
        //Get Product Id and qty
        $order = new WC_Order( $order_id );
        // Call the data store class so we can get bookings from the order.
        $booking_data = new WC_Booking_Data_Store();
        $booking_ids = $booking_data->get_booking_ids_from_order_id( $order_id );
        // If we have bookings go through each and update the status.
        foreach ( $booking_ids as $booking_id ) {
        $booking = get_wc_booking( $booking_id );
        $product_id = $booking->get_product()->get_id(); //Get product ID from booking
        //These two lines need converting to WCMV Marketplace
        $product_vendors = wp_get_post_terms($product_id,’wcpv_product_vendors’,array(‘fields’=>’ids’));
        $vendor_id = (int)$product_vendors[0]; //Vendor id
        $block_cost = get_post_meta($product_id, ‘_wc_booking_block_cost’, false)[0]; //Booking Block Costs
        $start_date = $booking->get_start_date();
        $end_date = $booking->get_end_date();
        //Calculate booking duration for the product
        $date_diff = strtotime($end_date) – strtotime($start_date);
        $duration = round($date_diff / (60*60*24));
        //Calculate total commission
        if ($duration > 4 ) {
        $total_commission = ($block_cost + ($block_cost*75/100)) *0.5;
        } else {
        $total_commission = $block_cost*0.5;
        //The following commission assignment needs converting to WCMV Marketplace
        global $wpdb;
        $table_name = $wpdb->prefix .’wcpv_commissions’;
        $update_commission = $wpdb->query($wpdb->prepare(“UPDATE $table_name SET total_commission_amount=%d WHERE order_id = %d AND vendor_id = %d”,$total_commission,$order_id,$vendor_id));
        do_action( ‘wcpv_commissions_updated’ );
        Thanks and regards,
    • #40893
      Here is your code for WCFM Marketplace –
      add_filter( 'wcfmmp_order_item_commission', function( $item_commission, $vendor_id, $product_id, $variation_id, $item_price, $quantity, $commission_rule ) {
      	$product_type = WC_Product_Factory::get_product_type( $product_id );
      	if ( 'booking' == $product_type ) {
      		$bookable_product = new WC_Product_Booking( $product_id );
      		$booking_base_cost = $bookable_product->get_cost( 'edit' );
      		$item_price -= $booking_base_cost; // Generate Commission on this Price
      		if( $commission_rule && is_array( $commission_rule ) ) {
      			switch( $commission_rule['mode'] ) {
      				case 'percent':
      					$item_commission = $item_price * ((float) $commission_rule['percent']/100);
      				break;
      				case 'fixed':
      					$item_commission = (float) $commission_rule['fixed'] * $quantity;
      				break;
      				case 'percent_fixed':
      					$item_commission = (float) $item_price * ((float) $commission_rule['percent']/100);
      					$item_commission += (float) $commission_rule['fixed'] * $quantity;
      				break;
      			$admin_fee_mode = apply_filters( 'wcfm_is_admin_fee_mode', false );
      			if( $admin_fee_mode ) {
      				$item_commission = (float) $item_price - (float) $item_commission;
      	return $item_commission;
      }, 50, 7 );
    • #40894
      Keep it more simple, don’t use previous code. Just use this ->
      add_filter( 'wcfmmp_order_item_price', function( $item_price, $product_id, $variation_id, $quantity, $vendor_id, $order_id ) {
      	return $item_price;
      }, 50, 6 );
    • #40950
      Pradeep M
      Hello again,
      Many thanks for the snippet. It works but with some issues. Basically in my setup, customers (renters) can rent items from multiple vendors for a single order. When I add 2 items (2 separate bookings) for a single order, it calculates and assigns the commission correctly to the first one but the other item, throughout the order, appears without a vendor – see the screenshot (https://www.awesomescreenshot.com/image/3798692/bc0630b513baa08ced5ce9a599660637). It doesn’t appear on the vendor’s account either.
      I have a couple of other related questions but I’ll hold them until I get this sorted. Is there a way for me to search your forum so I can see if anyone else has asked these questions before?
    • #40956
      I checked your image and found that second item is not a vendor’s product.
      Then why you are expecting commission calculation for that?
    • #40992
      Pradeep M
      That is the problem! It’s a vendor’ item that belongs to a different vendor but it’s coming up without vendor’s details on the order. And that order doesn’t appear on that vendor’s account either.
    • #41024
      “item that belongs to a different vendor but it’s coming up without vendor’s details on the order”
      – It’s impossible. Is that vendor previously created with your old multi-vendor plugin?
    • #41186
      Pradeep M
      No this is a brand-new instance, created just to test the capabilities of WCMV Marketplace. I just placed a new order by alternating the products and again it strips the vendor details from the second product in the order. Please see the screenshot. I am testing this on a local instance, otherwise I could’ve give you the access to have a look.
      https://www.awesomescreenshot.com/image/3799709/5d6c58b87800ce7e1b34bae395f8be61
    • #41188
      Pradeep M
      Here is a list of active plugins I have. I have the same plugins activated for the instance that is running WC Product Vendors plugin and it is working fine.
      https://www.awesomescreenshot.com/image/3799743/2468360ef0eef2419798e9cc044bb662
    • #41212
      WCFM Marketplace 2.0.4 has just updated.
      Kindly update yours and take a look now.
    • #41369
      Pradeep M
      That update did the trick and it is working fine now. Many thanks! I have a couple more questions and I will post them separately after searching the forums.
      Best regards,
    • #41375
      That’s great 🙂
      Sure, feel free to ask me those anytime.
  • The topic ‘Custom commission scheme based on WC Bookings block costs’ is closed to new replies.
