Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Custom Field Block to Top
- This topic has 2 replies, 2 voices, and was last updated 7 years ago by
sales.gearya.
- October 21, 2019 at 9:51 pm #88115
sales.gearya
ParticipantOn the vendors add product page when a custom field is entered it works great, but I would like for it to be listed as the top block. Currently it is showing “Inventory, Shipping, Tax, Attributes, Linked, MY CUSTOM FIELD BLOCK, Store, Commission.
I want to move the MY CUSTOM FIELD BLOCK to the first one, before Inventory. How would i go about doing this?
The screenshot is using “UPC Item Number” as the CUSTOM FIELD BLOCK i want to move up.Thanks for any help.
JamesAttachments:
You must be logged in to view attached files. - October 23, 2019 at 12:37 pm #88479
Kindly show me your “UPC Item Number” block screenshot.
- October 23, 2019 at 6:40 pm #88640
sales.gearya
ParticipantThanks for the reply. Attached is the sidebar tabs which are the default when a vendor is creating a new product. The custom field that was created is called UPC Item Number, which you can see is listed as the last of those tabs. I want to make the first listed tab. The main reason is because its a required field and when the vendor clicks to add the product if they have not added this field a warning comes up saying UPC is required, but it doesn’t open that block up so its confusing to the vendor. If it’s listed first, it will be open (similar to the way Inventory is open because its listed first). Can you help me to get it to the top?
JamesAttachments:
- The topic ‘Custom Field Block to Top’ is closed to new replies.
