Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Custom home pages for different membership levels
- This topic has 3 replies, 2 voices, and was last updated 7 years, 9 months ago by
- July 23, 2018 at 5:46 pm #26813
Wholistic
I have purchased the WCFM Ultimate and WCFM Staff and am trying to see how I can use membership plugin as well. I would be replacing another membership plugin I am currently using. However, there are a few features that seem to be missing. I posted in another thread about a Free membership level that can have the Store options turned off.
Also, I need to be able to have a custom home page for each membership level. Would this be possible with this plugin?
Thank you! - July 24, 2018 at 6:56 am #26849
WCfM – membership is specially only for store vendors. It’s not as general membership plugin for the whole site and normal users.
In general vendors are always redirect to their dashboard after login. Do you want to change this?
Actually, I am not getting clearly, what you mean by separate “Home page” for different membership levels!Thank You
- July 24, 2018 at 1:34 pm #26872
Wholistic
Yes, I want to change that. I want to be able to turn off the vendor dashboard for certain membership levels. What I mean by different Home page for different membership levels is upon login to redirect the user to a defined custom page (instead of the vendor dashboard). Can this be done with this plugin? - July 26, 2018 at 2:54 pm #26958
You may off course change redirect page after vendor’s login, just add this code –
function wcfm_custom_login_redirect( $redirect_to ) { return site_url(); } add_filter( 'wcfm_login_redirect', 'wcfm_custom_login_redirect' );It will redirect vendor to site’s home page after login, you may set something else as well.
But if you want set this membership wise then some level of customization required.
- The topic ‘Custom home pages for different membership levels’ is closed to new replies.
