Custom Product Tabs for WooCommerce
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Marketplace Custom Product Tabs for WooCommerce
Viewing 5 reply threads
    • #76766
      thiemann.k
      Hey Community,
      we want to use the Plugin “Custom Product Tabs for WooCommerce”.
      But how can i used it in Store Manager.
      When i create a new product in WooCommerce, then i can see the new tab from plugin. but when i add an new product by Store Manager it is missing.
      Can anyone help me?
      Ciao
      Karsten – dein-3d.com
    • #76896
      kaloomee
      I too vote for this feature please
      Existing Custom fields is great and would be wonderful if these custom fields could be located in a custom tab
    • #77443
      Well, WCFM already compatible with this Tab Manager plugin – https://woocommerce.com/products/woocommerce-tab-manager/
      WCFM Ultimate is require to avail this under store manager – https://wclovers.com/product/woocommerce-frontend-manager-ultimate/
    • #113258
      mercury
      I would love to see wcfm add a custom tab feature for videos, maps, files, etc. I would like to limit the number of plugins i install in my sites for security and load and an option like this will seamlessly integrated into wcfm because its your own. I too bought Elegant Tabs only to find out it doesnt show up in the wcfm console which is frustrating and a waste of $$$$$. Hope you can consider. Thanks
    • #114825
      WCFM has in-built custom field module – https://wclovers.com/knowledgebase/wcfm-custom-fields/
      You may use this and show custom field under your product page.
    • #141761
      zorb-designs.com
      NO but we should be able to remove unwanted tabs? There have been two tabs added to my products that I don’t want.. How Can i remove those?
  • The topic ‘Custom Product Tabs for WooCommerce’ is closed to new replies.
