Diwali
05Day 05Hr 07Min 22Sec
Diwali
Customers not pulling through to WCFM
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Customers not pulling through to WCFM
Viewing 11 reply threads
    • #34543
      jadenew
      Hi there,
      I have the following setup:
      Wyzi directory theme (using WC Marketplace)
      WCFM
      Now when a customer places an order, I – as a vendor – would expect to see this customer in WCFM’s tab “CUSTOMERS”. However I don’t. Is that intentional and am I only able to see customers I have manually added – or – is that a bug and vendors should automatically see all customers that have ever placed an order with them?
    • #34770
      Can you please know me one thing, that user placed the order what is user role for that user?
      If that user’s role is “customer” then it will be definitely under customer dashboard.
    • #34823
      jadenew
      It is a Wyzi custom role called “Client”.
      Thing is I have vendors who don’t have a “Customer” user role and vendors can also place orders. That would mean that they would not show up in the list. If I add additional role to all users to be “Customer”, would that work?
    • #34870
      Can you please add this line of code to your site –
      add_filter( 'wcfm_customer_user_role', function( $customer_roles ) {
        return 'customer, client';
    • #35686
      jadenew
      Hi and thank you for the snippet but it didn’t work unfortunately. I have put it in child’s theme functions.php and also tried adding it via a PHP snippet WP plugin.
    • #35702
      Please be sure your custom user role “client”?
    • #36230
      jadenew
      Hi there,
      yes it is. That’s how I tested it.
    • #36311
      I understand this problem, will resolve in next update.
      Between, that custom code no more required.
    • #36530
      jadenew
      Hi, when will be the next update please? What you mean code is not required? Thank you
    • #36533
      I have give you this code –
      add_filter( ‘wcfm_customer_user_role’, function( $customer_roles ) {
      return ‘customer, client’;
      It’s no more required.
      Between, next update will be there in 2-3 days.
    • #36681
      jadenew
      Excellen,t thank you so much! 🙂
    • #36886
      WCFM new update already released.
  • The topic ‘Customers not pulling through to WCFM’ is closed to new replies.
