Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Customize PDF Invoice
- This topic has 14 replies, 4 voices, and was last updated 7 years, 11 months ago by
- October 2, 2017 at 11:49 pm #13873
david2
We already use the “WooCommerce PDF Invoices & Packing Slips” plugin to customize the Woocommerce invoice, and purchased the “WCFM Ultimate” because of it’s compatibility with it. However, I noticed that the PDF created by “WCFM Ultimate” is not using the custom template that is in my child theme. We don’t want the commission amount visible, or any of the other extra details in the “WCFM Ultimate” version. The “WCFM Ultimate” version also doesn’t display customer notes. How can we get “WCFM Ultimate” to use the normal (or custom) PDF templates?
The PDF displays properly when exported from Woocommerce directly, but our vendors only have access to the functionality in “WCFM Ultimate”, and we would like the PDF to look the same. (please see attachment for reference)
You must be logged in to view attached files. - October 3, 2017 at 9:14 pm #13891
david2
ParticipantTo be clear, I want “WCFM Ultimate” to use the default PDF template from the “WooCommerce PDF Invoices & Packing Slips” plugin. Can you please help? I noticed that the PDF in the demo has a big logo header, so I assume customization is possible somehow.
- October 4, 2017 at 5:27 pm #13912
WCfM Forum
WCFM vendor PDF invoice template is just slight modification of WooCommerce PDF invoice and Packing Slips default template to support vendor specific columns – commission and others.
Custom template not possible to support right now.
PDF Invoice plugin has some settings options for template header and footer, those are maintained here as well.
Do you want to have settings option as we have in demos, kindly know me I will show you those as well.
- October 4, 2017 at 6:32 pm #13913
david2
ParticipantThank you so much for the reply! Your time is greatly appreciated. Is there a way to connect the “WooCommerce PDF Invoices & Packing Slips” plugin to “WCFM Ultimate” directly? So we wouldn’t have to use the modified template at all? We don’t need vendor specific info. We just want the vendor to be able to use “WooCommerce PDF Invoices & Packing Slips” the same way it works in the admin dashboard.
- October 4, 2017 at 8:18 pm #13916
WCfM Forum
I can’t say that is impossible.
But just to clarify one thing, do you want to have the Custom template for invoice?
And more to mention, in such case whole order will be in invoice, not only the part of Vendor, is this this fine for you?
- October 4, 2017 at 8:52 pm #13917
david2
ParticipantNo, I don’t need a custom template. Just the normal one that comes with the “WooCommerce PDF Invoices & Packing Slips” plugin is fine. And yes, that is fine. We just want the vendor to be able to print the normal invoice without the vendor specific details.
- October 4, 2017 at 9:45 pm #13919
WCfM Forum
Ok fine, that’s great.
To achieve this needs some coding customization. I will do that for you, don’t worry.
Just tell me, what will be preferable for you to integrate to those custom codes – child theme functions.php or a custom plugin?
I will wrap the code in such a way.
- October 4, 2017 at 10:10 pm #13920
david2
ParticipantA plugin would probably be better, in case we switch the child theme in the future. Either way would be fine though, as I am comfortable with implementing both. Thank you so much!
- October 5, 2017 at 3:13 pm #13929
Shhiv Narayan
Ok fine.
Better I will send you a custom plugin for that.
In case you change your theme in future or implement the same in another site then plugin will be easier to carry over.
I will send that by tomorrow.
- October 5, 2017 at 6:11 pm #13941
david2
ParticipantSounds good to me! Thank you much!
- October 6, 2017 at 12:10 am #13957
WCfM Forum
Can you please know us which multi-vendor plugin you are using in?
Thanks in advance
- October 6, 2017 at 1:39 am #13959
david2
ParticipantYes, we are using the “WC Vendors” free plugin.
- October 6, 2017 at 1:49 am #13964
Shhiv Narayan
MemberAhh .. thanks.
I will send you Custom Plugin in few hours.
- October 6, 2017 at 6:36 pm #13976
david2
ParticipantLooking forward to it. Thank you for all your help!
- October 7, 2017 at 5:05 am #13991
I am sorry for a bit delay.
PFA, custom plugin for Order details/Invoice as Admin for Vendors.
Kindly install this plugin to your site and take a look.
Please know me if you are looking for any further changes.Thank You
ShhivAttachments:
- The topic ‘Customize PDF Invoice’ is closed to new replies.
