Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Customize translations of vendor menu
- This topic has 5 replies, 3 voices, and was last updated 6 years, 5 months ago by
- April 28, 2020 at 1:17 am #123887
Gregorio
ParticipantHi, I need to better translate some terms in the Vendor and Store Admin menu.
As for examle the word SEGUACI in the picture that in Italian has a totally different meaning
I use WPML plug in (that made me crazy to be properly configured since it’s not immediatelly compatible with WCMF) but I don’t know where I can manage and translate Menu texts.
ThanksAttachments:
You must be logged in to view attached files. - April 28, 2020 at 11:28 am #124055
There is a simple way of doing this using Menu Manager. To access the page go to your WCFM admin dashboard >> Settings >> Menu Manager. From here you’ll have total control over the ordering and wording of your menu items. You can even add new menu items or remove the existing ones. Menu items visibility can also be controlled by setting it Vendor only, admin only, or both.
For any other translate related issue use Loco translate (if your site is not multilingual).
Thank You! - April 28, 2020 at 1:49 pm #124114
Gregorio
ParticipantHI, this is not what I’m looking for. As you can see there is no correspondence between the text in the dashboard and the menu. What I want to modify, for example, is the word SEGUACI on the left. In the menu setting is called FOLLOWERS, so note the same.
We use WPML and have asked already support to WCLovers configure it because it sets English as primary language.Attachments:
You must be logged in to view attached files. - April 28, 2020 at 6:05 pm #124255
Please change the text ‘Followers’ to anything you want to show, from Menu Manager. It should work. There is a translation of the text ‘Followers’ is present in your language (in our pot file) so it’s showing that value. When you change that text it will not be able to translate that.
Thank You! - May 13, 2020 at 12:45 pm #130327
Qualivery srls
ParticipantAre there any way to change the translation of this field?
You must be logged in to view attached files. - May 15, 2020 at 1:04 pm #131284
KeymasterYou can do so using the Loco Translate plugin. Go to Loco translate (wp-admin menu) >> Plugins >> WCFM – WooCommerce Frontend Manager >> and edit Italian language. Search for the text ‘Email’ and make changes as per your need. Ref: https://easyupload.io/8onj94
- The topic ‘Customize translations of vendor menu’ is closed to new replies.
