Customized product thumbnails from Fancy Product Designer not displayed
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Customized product thumbnails from Fancy Product Designer not displayed
Viewing 1 reply thread
    • #99618
      patrice.baudin
      We installed the Fancy Product Designer plugin that you recommand and offer compatibility with WCFM. We have been experiencing issues with the thumbnail of products that users customize then save: the original blank product thumbnails are displayed in the shopping cart instead of the customized product thumnails. This is very confusing for the users because they don’t know if the product they have customized are the ones listed in their shopping cart.
      Our php.ini file does match FPD requirements (setting are: memory_limit = 128M / upload_max_filesize = 16M / post_max_size = 16M), so the issue might be on WCFM side.
      Can you please help?
      Thanks in advance.
      Regards.
    • #100639
      patrice.baudin
      Is there someone from WCFM replying in this forum?
      Please help.
      Thx
  • The topic ‘Customized product thumbnails from Fancy Product Designer not displayed’ is closed to new replies.
