Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Dashboard menu text not showing
- This topic has 3 replies, 2 voices, and was last updated 5 years, 7 months ago by
Ramamurthy Krishnan.
- February 5, 2020 at 6:23 am #105485
owusuoppongemmanuel
ParticipantHello, from vendor dashboard, the text fields do not show text entered into them. I realized the problem can’t be fixed no matter the colour scheme I use even when I turn everything to default. I am using woodmart theme contacted them and they suggested getting the CSS side for those field from you. I am attaching an image and you will see that all the text are not showing but only shows when I select the input in those text field.
Thank youAttachments:
You must be logged in to view attached files. - February 5, 2020 at 1:31 pm #105520
Ramamurthy Krishnan
KeymasterIt seems as a css issue but no worries just share us your website login details with us, we’ll check it and get back to you.
Please do share your website login credentials as private reply here.
- February 5, 2020 at 4:21 pm #105538
owusuoppongemmanuel
ParticipantThis reply has been marked as private. - February 10, 2020 at 7:07 pm #106510
Ramamurthy Krishnan
KeymasterHi@owusuoppongemmanuel,
Please send us your website link to login using the username & password you sent.
2. After store wizard, I want to direct vendors to a page of training before a visit to the dashboard or a page for the knowledge base. How do I add content to the knowledge base?
add_filter( 'wcfmmp_store_setup_steps', 'wcfm_set_complete_redirect', 10, 3 ); function wcfm_set_complete_redirect( $default_steps ) { $default_steps['next_steps']['view'] = 'cus_wcfmmp_store_setup_ready'; return $default_steps; }; function cus_wcfmmp_store_setup_ready() { ?> <h1><?php esc_html_e( apply_filters( 'wcfm_store_setup_complete_heading', __( 'We are done!', 'wc-frontend-manager' ) ) ); ?></h1> <div class="woocommerce-message-wcfm woocommerce-tracker"> <p><?php echo esc_html( apply_filters( 'wcfm_store_setup_complete_message', __( "Your store is ready. It's time to experience the things more Easily and Peacefully. Add your products and start counting sales, have fun!!", 'wc-multivendor-marketplace' ) ) ); ?></p> </div> <div class="wc-setup-next-steps"> <p class="wc-setup-actions step"> <a class="button button-primary button-large wcfm_submit_button" href="<?php echo esc_url( site_url() ); ?>"><?php esc_html_e( apply_filters( 'wcfm_store_setup_complete_button', __( "Let's go to the Dashboard", 'wc-frontend-manager' ) ) ); ?></a> </p> </div> <?php }
I’ve changed the dashboard url to website url of “Let’s go to the Dashboard” button, you can change the url and content according to you inside the “cus_wcfmmp_store_setup_ready” function.
3. Can there be a toggle between register as a vendor and as a customer from the my account sign up?
Yes it can be done, it will require custom development, please contact us here for the purpose: https://wclovers.com/setup-guidance/Thanks,
