Dashboard Settings | Hide Timezone
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Dashboard Settings | Hide Timezone
Viewing 3 reply threads
    • #40062
      Jay
      Hi Team,
      Is there any way I can hide Timezone Setting, without touching the core file?
      I can’t find hook for it.
      wp-content/plugins/wc-frontend-manager/views/settings/wcfm-view-wcmarketplace-settings.php
      <p class=”tzstring wcfm_title wcfm_ele”><?php _e(‘Timezone’, ‘wc-frontend-manager’); ?><span class=”img_tip” data-tip=”<?php _e(‘Set the local timezone.’, ‘wc-frontend-manager’); ?>”></span></p>
      <label class=”screen-reader-text” for=”tzstring”><?php _e(‘Timezone’, ‘wc-frontend-manager’); ?></label>
      <select id=”timezone” name=”timezone” class=”wcfm-select wcfm_ele” style=”width: 60%;”>
      <?php echo wp_timezone_choice( $tzstring, get_user_locale() ); ?>
      </select>
      Jay
    • #40079
      Add this CSS to make this disable ->
      #wcfm_settings_form_identity_expander .tzstring, #wcfm_settings_form_identity_expander #timezone {display:none;}
    • #40166
      Jay
      Thanks for your help.
    • #40190
      You are welcome, have a great weekend 🙂
  • The topic ‘Dashboard Settings | Hide Timezone’ is closed to new replies.
