wcfm-santa
The New Year has begun! Avail upto 25% OFF on WCFM Addons.
01Day 07Hrs 44Min 12Sec
Dashboard settings (small amendments) – 2
Multi Vendor Marketplace Plugin | WCFM Marketplace Forums WCFM Dashboard settings (small amendments) – 2
Viewing 7 reply threads
    • #13970
      plamen
      Apologies for opening another topic, but the original one was closed for comments.
      Yes, it is fine now, thanks! Only one small thing that I see: on the Dashboard, when you go to “Orders”, in the order itself, the vendor still sees the net amount (after deduction of commission), showing as “commission” in the table. The table has the following columns: cost (the gross amount), quantum, commission (the net amount after deduction the commission). The perfect table would be to have: unit price, quantity and total price (all based on the gross price, not taking commission into account), but if this is too difficult, I would be happy just to have the column with header “Commission” removed (as long as the column “Cost” is showing the total amount, not the price per unit.
      I am sorry for being so difficult, I hope this is not so complicated to achieve (by adding or amending some code).
      Regards,
    • #13973
      WCfM Forum
      I am sorry, by some mistake the old thread closed.
      I am looking into these, what can I do for this.
      But probably it will be a custom solution for you, I will send you a custom plugin to achieve this.
    • #13978
      Plamen
      I think that it may have something to do with WC Marketplace, because when I send a test order, the test email to the vendor also shows the column “Commission”. But this seems to be from WC Marketplace, not from the Front Manager (it’s automatically translated and the Front Manager plugin does not support that language). I will figure that our at a later stage…
    • #13997
      PFA, custom plugin for modified Order Details page without “Commission column”.
      Kindly install this and take a look.
      Please know me if need any further changes in this.
    • #14015
      Plamen
      Thanks for this! However, I have no login details for the forum, so I have no access to the attachment. It may sound a bit stupid, but I could not find any sign up link for new users (it should be me :)).
    • #14019
      I am really for that.
      Please register from her: http://wclovers.com/my-account/
      And kindly download custom plugin from here:
      https://drive.google.com/file/d/0B5mkZCm38AGVNlBPYkxsVUlvdU0/view?usp=sharing
      Really sorry for the harassment.
    • #14026
      Plamen
      All fine, thanks!
    • #14036
      WCfM Forum
      Ahh .. great.
  • The topic ‘Dashboard settings (small amendments) – 2’ is closed to new replies.
