Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Disable Responsive Float Menu is missing
- This topic has 7 replies, 3 voices, and was last updated 6 years, 9 months ago by
- August 20, 2019 at 7:39 pm #77562
Pitz
I have recently been doing some updates to my site and noticed the “Disable Responsive Float Menu” settings option seems to be missing as of current version 6.2.7 and when viewing my wcfm dashboard on a small mobile device, the menu is no longer at the bottom like I had it.
Is this intentional? I am hoping it is just a mistake because I think the responsive menu at bottom is much better for my site.
I have not checked the dashboard on mobile in a month or two so am not exactly sure when it changed, I assume it happened with one of the updates.Please let me know how to get the responsive menu at bottom again, thank you!
- August 22, 2019 at 12:14 pm #77769
inspire
ParticipantSame problem, please do something, now is impossible to do anything as admin or vendor from mobile phones because you can not see a half of screen.
- August 22, 2019 at 4:26 pm #77812
– Yeah, we have remove this option as it’s causing lots of problem with many themes.Same problem, please do something, now is impossible to do anything as admin or vendor from mobile phones because you can not see a half of screen.
– Why this? mobile menu is toggledThank You
- August 23, 2019 at 6:11 am #77948
Pitz
That is disappointing to hear that it was removed intentionally.
I understand if there’s compatibility issues with some themes, but why not leave it off as default and keep the option to enable it like all the other settings options?
I used Storefront in the past and currently use Astra, both popular Woocommerce themes, and never had a compatibility issue due to mobile float menu.
I know regular mobile menu can be toggled but UI is not as good, the mobile float menu was very nice feature because it feels more “app-like” for mobile devices and my vendors liked it.
Is there really no way to just keep it as an optional setting?
Thank you. - August 27, 2019 at 11:16 am #78514
- August 28, 2019 at 4:37 pm #78786
MemberWell, that left menu is form your theme, right?
- August 29, 2019 at 10:27 am #78922
inspire
ParticipantThat is the WCFM menu.
- August 30, 2019 at 5:10 am #79118
Please check this – https://www.loom.com/share/b055ba2aa3ea4e9599033df648269b2c
If menu collapse-open not working then definitely there has some JavaScript error in your site.
Please clear your site caches once as well.
- The topic ‘Disable Responsive Float Menu is missing’ is closed to new replies.
