Disabling "short description" field when adding a product
Viewing 1 reply thread
    • #44469
      Samiul
      I want to disable the short description tab when a vendor is adding a product.
      I will be happy if you share the php script for this to add in theme’s function.php file
    • #44480
      Do you have WCFM Ultimate? then you may do this easily from WCFM Capability setting.
      If not, know me. I will give you code snippet for this.
  • The topic ‘Disabling "short description" field when adding a product’ is closed to new replies.
