Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Disconnect from stripe fail
- This topic has 3 replies, 1 voice, and was last updated 6 years, 4 months ago by
EK.
- March 21, 2019 at 10:03 am #53806
EK
I am running a lot of tests to test the codes which you had sent me via email (Thank you and I will reply to your email with results).
As part of my tests, I am trying to disconnect a vendor who was migrated from wcmp to your plugin using the migration plugin. I connected him to stripe in test mode (However I may have clicked on ‘skip this account form’ to connect) but clicking disconnect is leading to wordpress account page.On returning to my-shop–>payments as vendor , I see he has not disconnected from stripe.
The other vendor which I created in your marketplace plugin is easy to remove and re-connect.
The migrated vendor is connected to my production site as a live vendor with test keys saved in production (since we tested production before launch).
So, can you kindly let me know
1. how to force the vendor to disconnect. (Maybe database level?)
2. Since he was migrated from wcmp,and he had test stripe keys saved in wcmp, do you think this is what is causing the issue with disconnecting? (We cloned production to test migration to your plugin meaning in production he had stripe test keys saved in wcmp)
Thanks a lot for your advise.
Best Regards,
Ak - March 21, 2019 at 10:08 am #53807
EK
ParticipantThis reply has been marked as private. - March 21, 2019 at 10:40 am #53808
EK
ParticipantUpdate: I found a workaround: Delete test keys as admin and vendors get disconnected. However, kindly comment your thoughts since this is not the right way of disconnecting. I will update more test results relevant to this issue.
- March 21, 2019 at 12:44 pm #53825
EK
- The topic ‘Disconnect from stripe fail’ is closed to new replies.
