Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Do I need to use Stripe split pay if 100% is going to vendor…?
- This topic has 5 replies, 2 voices, and was last updated 7 years, 5 months ago by
- April 9, 2019 at 8:00 pm #57033
pdishman
ParticipantTrying to set up connected accounts and it occurred to me that I may not need to use split pay if I’m paying 100% to my vendors and setting up as “Direct Charges” on Stripe. Is that correct?
Also since I’m not taking a commission, would I select platform payments or card payments when setting up Stripe connected accounts. I need to know if WCFM needs my settings to be a certain way, or if it is completely up to us depending on the way we operate our marketplace,
- April 10, 2019 at 1:29 pm #57143
Yeah please, otherwise total amount will be created in Admin account then you have to transfer 100% commission into vendor’s account.
- April 10, 2019 at 6:32 pm #57190
pdishman
ParticipantThats where I’m confused, because if I use “direct charges” stripe, as I understand it, places funds in the connected vendors account…
- April 11, 2019 at 5:22 pm #57315
Right, still go though this to understand Stripe different charges – https://stripe.com/docs/connect/charges
- April 22, 2019 at 7:30 pm #58954
pdishman
ParticipantSo in my dashboard under the withdrawal tab, should i have both stripe and stripe split pay checked or just stripe split pay – currently I have the both checked, but I’m wondering if that is incorrect? Also should I select platform payments or card payments on Stripe set up side, if I’m using direct charges…?
One of the things I’m confused about is when the vendor connects to stripe from my dashboard are they then the ones accepting payment or is my platform (WCFM) accepting payment? Not understanding this makes it hard for me to know how to set this up on Stripe Side.
Thank you!Attachments:
You must be logged in to view attached files. - April 24, 2019 at 9:06 am #59140
– Well, if you have enabled Stripe Split Pay then Strip is no more required, you may disable this.
– Please go thought this for Stripe setting – https://docs.wclovers.com/vendor-payment/
- The topic ‘Do I need to use Stripe split pay if 100% is going to vendor…?’ is closed to new replies.
