Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Does not calculate commission percentage assigned to you
- This topic has 0 replies, 1 voice, and was last updated 2 years ago by
yeisson.p.a.
- April 25, 2020 at 1:44 pm #122848
yeisson.p.a
ParticipantIn Configuration, he assigned a percentage commission of 20% and I select that the shipment stops for the client, so that he does not charge a shipping commission. I did several tests and it does not calculate the commission as it should be, apparently the percentage changes due to a certain amount and also does not take into account the option of not calculating commission in the shipment.
—-Spain—–
No calcula el porcentaje de comisión que le asignóEn Configuración le asignó una comisión de porcentaje del 20% y selecciono que el envío para para el cliente, para que no cobre comision del envío. hice varias pruebas y no calcula la comisión como debería de ser, al parecer cambia el porcentaje debido a cierta cantidad y además no tiene en cuenta la opción de no calcular comision en el envio.
