Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Elementor Dynamic integration with WCFM store infos
- This topic has 0 replies, 1 voice, and was last updated 5 years, 9 months ago by
Cap Luis.
- November 1, 2019 at 11:09 pm #90169
Cap Luis
ParticipantThere is an option in the dynamic data integration element, an example is the text block, I can dynamically populate data, from plugins like PODS, ACF, etc. In this case the text displayed must be filled from an external source, not the manually filled text in the text editor.
Wcfm has a lot of information like: Store Bio, Store Policies! This information is accessed by tabs that are not “ajax”. If you do not have a cache of this information loaded, it may be a little slow to get the data from these tabs open.
I wish I could provide this information where Elementor page builder allows it. In that case you could create specific widgets for: Bio, and Politics. And it could also add widgets for followers, and store reviews.
So you could expose these details where I prefer.
Another integration that could be done, if that were something simple. The store map could use the Elementor map! so I could define the size of the map and where to display this map. Today I can only use a default widget in wordpress sidebars.
I believe that if these little details are improved, a 5 star rating would be more than fair.
Without these items I can rate it as 4 stars ^ _ ^
- The topic ‘Elementor Dynamic integration with WCFM store infos’ is closed to new replies.
