Elementor Plugin – bugs
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Elementor Plugin – bugs
Viewing 2 reply threads
    • #98278
      ashley.younguk
      Hi
      I’ve noticed a few bugs with your new Elementor addon.
      Inquiries
      When using the inquiry button on the vendors store page template it brings up the inquiry form, but when you complete it – it doesn’t log it anywhere at all so the vendor doesnt see the inquiry and the customer doesnt see it in their account.
      Other options
      When using the dynamic options you’ve added such as Store Name it does work. So for example – I am creating a single product template and I would like to add the store name using either the dynamic option within elementor or the elementor widget you’ve created and it shows the user name of the person viewing the page rather than the store name of the product.
    • #98635
      – We are debugging this.
      Other options
      – Do you have used “Store Info” widget or some other widget? Pleas show me screenshot.
    • #100840
      ashley.younguk
      Hello
      Just wondering how your getting on with debugging these issues?
      When adding the ‘Store Name’ widget it just adds a header widget, however I have managed to find a work around for this.
      As I’ve been using the Elementor Plugin I have a few suggestions for widgets:
      – Adding your shortcode as a widget and allow the user to select the information they would like to display, such as store_location etc…
  • The topic ‘Elementor Plugin – bugs’ is closed to new replies.
