Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › error on checkout with stripe
- This topic has 6 replies, 2 voices, and was last updated 5 years, 9 months ago by
- May 7, 2020 at 11:22 pm #128134
TIAD83
Participanthi team, got everything working great but when i use split pay i’m getting this error.
Error creating customer record with Stripe: Unexpected error communicating with Stripe. If this problem persists, let us know at support@stripe.com. (Network error [errno 2]: easy handle already used in multi handle)
Stripe Split Pay Error: Unexpected error communicating with Stripe. If this problem persists, let us know at support@stripe.com. (Network error [errno 2]: )everything work if i use woocommerce stripe payment.
- May 8, 2020 at 6:46 pm #128425
Stripe and Stripe split pay works differently. They even use different API.
From the error it seems there might be some configuration error on your stripe account. I would request you to connect with your Stripe account manager for this.
Also please go though our documentation page https://docs.wclovers.com/vendor-payment/#stripe-split-pay and make sure you have completed all the steps.
Looking forward to helping you.
Thank You!- May 8, 2020 at 9:10 pm #128481
TIAD83
Participanthi, did a test using
3D Secure and SCA ready transaction is only supported when both your platform and the connected account (Vendor) are in the same region: both in Europe or both in the U.S.
if i enabled this feature the the payment works, but Stripe Split Pay does not work and vendor dont get customer payment instead it goes to admin stripe account dashboard.
if i disabled and enable Stripe Split Pay i get this
- May 8, 2020 at 11:17 pm #128539
Are you using any other Stripe plugin in your site except WCFM Stripe Split pay? If yes, then please deactivate that.
Please check at wp-admin -> WooCommerce -> Status -> Logs -> wcfm-stripe log -> is any error generated?
Lastly, as I suggested earlier, please contact your Stripe account manager.
Thanks You!- May 9, 2020 at 2:53 am #128616
TIAD83
Participantthis is the membership logs. the payment goes through then i get this error. and i can see the payment on my stripe dashboard.
2020-05-08T16:07:20+00:00 DEBUG WCfMvm IPN Received –>
2020-05-08T16:07:20+00:00 DEBUG Stripe SCA Subs IPN received. Processing request…
2020-05-08T16:07:20+00:00 Error occurred: Unexpected error communicating with Stripe. If this problem persists, let us know at support@stripe.com.(Network error [errno 2]: easy handle already used in multi handle)
2020-05-08T21:11:15+00:00 DEBUG WCfMvm IPN Received –>
2020-05-08T21:11:15+00:00 DEBUG Stripe SCA Subs IPN received. Processing request…
2020-05-08T21:11:15+00:00 DEBUG Sandbox payment mode is enabled. Using test API key details.
2020-05-08T21:11:15+00:00 Error occurred: Unexpected error communicating with Stripe. If this problem persists, let us know at support@stripe.com.(Network error [errno 2]: easy handle already used in multi handle)
2020-05-08T21:19:27+00:00 DEBUG WCfMvm IPN Received –>
2020-05-08T21:19:27+00:00 DEBUG Stripe SCA Subs IPN received. Processing request…
2020-05-08T21:19:27+00:00 DEBUG Sandbox payment mode is enabled. Using test API key details.
2020-05-08T21:19:27+00:00 Error occurred: Unexpected error communicating with Stripe. If this problem persists, let us know at support@stripe.com.(Network error [errno 2]: easy handle already used in multi handle)
- May 9, 2020 at 9:20 am #128703
TIAD83
ParticipantOk i fixed the issue. got help from this link talking about stripe.
https://github.com/stripe/stripe-php/issues/918removed this code from
wp-content/plugins/wc-multivendor-marketplace/includes/Stripe/lib/HttpClient/CurlClient.php
$this->enablePersistentConnections = function_exists(‘curl_reset’);and add this code
$this->enablePersistentConnections = false;problem fixed
- May 10, 2020 at 1:06 pm #129096
KeymasterGreat to know. I have sent those links to our dev team as well. Thank You for your help.
