Filtering by custom field "date" not working
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Filtering by custom field "date" not working
Viewing 1 reply thread
    • #96892
      koziol911
      I have added a custom field “date123” with “date picker” field type to a product. It works fine, I can add a date to products. But there is no way I can get any filter plugin to work with this field. I have tried MDTF, WOOF, Product Filter for WooCommerce.
      I can get the closes with WOOF, which allows to search for meta data as TEXT and then successfully finds the products. But when I use WOOF date picker, it does not show any results. I think there might be a conflict in field format – it is treating meta data in field as text, no date.
      I know, these are not your plugins, but do you know how to resolve this? Or perphaps you know any plugin that can work with this?
      I am planning to by WC Appointments plugin, but now I am afraid if it works with WCFM and this fields.
      Best regards,
      Mateusz
    • #97174
      – Kindly check, are both date picker format is same or not? When creating product and search field!
      If those are same then it will definitely do this search.
      Between, WC Appointments has own search widgets. No need to search using meta data.
  • The topic ‘Filtering by custom field "date" not working’ is closed to new replies.
