Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Follow button
- This topic has 5 replies, 3 voices, and was last updated 6 years, 5 months ago by
osobrowser.
- November 26, 2018 at 9:42 pm #38217
Sofia
GuestHi!
I want to add a follow button with the shortcode “[wcfm_follow store=””]”, but does not work!.
Also I have activated “Followers” in capacities but no show any button for see that in vendor panel.Any one can help me?
- November 27, 2018 at 6:42 am #38295
You have to specify store id here ->
[wcfm_follow store="4"]
- January 22, 2019 at 9:34 am #44660
Linda Benefield
GuestI have tried everything, but i cannot get the button for follow store to work! it doesn’t even show up! the inquiry does just fine, but not the follow!! I want it to be a button at the top of the banner or header or sidebar and make it so it will automatically know the store ID too! I don’t want to have to make a separate shortcode for every single store! I may end up with hundreds of stores, so that will take alot of time and effort. Can you just make it into a widget like you did everything else???? that would be so much easier! or build it into the heading! thanks!
- March 25, 2019 at 9:26 am #54424
Rajesh
GuestReference: http://www.mysahar.com/arambagh/seller/xenon-it-hub/
1. No follow button appears in vendor store pages.
2. No filter options and pagination shows in vendor store pages. I tried this code,#wcfmmp-store-content .shop-loop-before, #wcfmmp-store-content .shop-loop-after { display: block !important; }
it displays the options but nor working.
3. In vendor store header page, when address fields become 2 lines then there is no space remains under phone number/e-mail fields.
4. Pagination in store listing page is also not working.What will I do now?
- March 26, 2019 at 2:51 pm #54574
Well, Follow button is coming with WCFM Ultimate.
If you already have this then be sure it’s enable at WCFM Admin Setting -> Modules and at WCFM Capability
4. Pagination in store listing page is also not working.– Please give me this URLs to check.
- March 27, 2019 at 6:54 am #54749
osobrowser
Participant3. http://www.mysahar.com/arambagh/seller/meem-security-and-allied-services/
4. http://www.mysahar.com/arambagh/all-stores/And What about the problem of 2. ?
- The topic ‘Follow button’ is closed to new replies.
