Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Followers
- This topic has 24 replies, 4 voices, and was last updated 6 years, 3 months ago by
musikapublishing.
- January 30, 2020 at 5:17 am #104617
r_guayaquil
What does the follower option does? I have enable the option but not really sure what it does. I even try to follow a vendor but nothing happens
Is the user who follows a specific vendor? The user has to register in the website in order to follow a vendor? what are teh benefits for the user to follow a store, does the user recieve email notifications when a vendor publish a new product or puts a product on discount?
I hev tried to look in the documentation but no luck.
Thanks for the help!
- January 31, 2020 at 4:08 pm #104789
Sarmistha Chakraborty
Basically this is hoe it works-
Any registered users follows any vendors and all this user can check all the list of vendors they are following in the “following” tab. Similarly the vendors can see the list of followers in “Followers” tab in vendor Dashboard.
- February 11, 2020 at 9:57 pm #106734
r_guayaquil
So it only shows who the user is following. The user dont get any email notification is the vendor his following publish a new product right?
- February 12, 2020 at 1:13 pm #106811
MemberHii,
If an user follow a vendor then whenever a new product will publish to that vendor’s store followers will be notified.
- March 11, 2020 at 3:05 am #111046
r_guayaquil
How does the user is notified when the vendor publish a new product? I am following a vendor and the he published a new product but i didnt get notified 🙁
- March 20, 2020 at 9:23 am #112350
r_guayaquil
Any help? 🙂
- March 20, 2020 at 2:18 pm #112372
Customer will be notified by mail.
You can check the customer was receiving the mail or not using “WP Mail Logging by MailPoet” plugin(https://wordpress.org/plugins/wp-mail-logging/)Thanks.
- March 20, 2020 at 9:39 pm #112427
r_guayaquil
I have installed the plugin but the email notification is not being sent to the customer.
Thanks for help!
- March 26, 2020 at 10:25 am #113235
r_guayaquil
some help 🙂
- April 7, 2020 at 2:56 am #116123
r_guayaquil
Participanthi,
please some help!
- April 7, 2020 at 7:24 pm #116406
soumanta
KeymasterWe have tested the latest version(6.4.7) of the plugin & the “following” email for new product working just fine. Do you have any customization on your site? If the problem still exists, we may need access to your website to debug the issue. Don’t forget to set your reply as private.
- April 8, 2020 at 8:20 am #116705
r_guayaquil
ParticipantThis reply has been marked as private.- April 8, 2020 at 5:57 pm #116879
soumanta
KeymasterWe have tested the problem in your site & created two demo users ( “test.vendor” , “test.user” ).
Then we follow the new store for “test.vendor” using two accounts – “test.user” (wclovers.soumanta+5@gmail.com) & “RGuayaquilF22” (r_guayaquil@hotmail.com).
Now we create a new product from Frontend (https://www.todomerca.ec/mitienda/products-manage/).
“New product” emails are sent to the followers (wclovers.soumanta+5@gmail.com, r_guayaquil@hotmail.com) successfully.
We have also checked email log using “WP Mail Logging by MailPoet” plugin (https://wordpress.org/plugins/wp-mail-logging/).(see screenshot e390810c-f69e-47cf-85f3-2bd68b4811y9.png)
You can confirm the same by checking mail at r_guayaquil@hotmail.com for “New product” email.(see screenshot 3de91824-dfd4-4cef-b590-809c42539eb7.png)Attachments:
- April 8, 2020 at 8:30 am #116711
r_guayaquil
Also, for some reason the custom fields i created are showing in the “about us” tab in the vendor store. See image attached.
Thanks for the help
You must be logged in to view attached files.- April 8, 2020 at 6:00 pm #116882
soumanta
KeymasterThis code snippet is causing the problem.(https://www.todomerca.ec/wp-admin/admin.php?page=edit-snippet&id=27)
Please remove it & check again.
- April 9, 2020 at 3:08 am #117051
r_guayaquil
The problem was because the vendor needed approval from the admin to publish a product. IF the vendor needs an approval then the user doesnt get the email notification, but if he doesnt need approval and publish his products then the user gets the notificacion. What can i do so the user gets the notification even if the vendor needs an approval from admin?
And about the code snippet, you guys helped me with that code to show the custom fields under the price in the quick view and in the product detail page. I can remove it. I need it to look like that.
Thanks a lot for the help!
- April 13, 2020 at 11:35 am #118645
r_guayaquil
Help please!
- April 13, 2020 at 4:56 pm #118729
soumanta
KeymasterAnd about the code snippet, you guys helped me with that code to show the custom fields under the price in the quick view and in the product detail page. I can remove it. I need it to look like that.
Please replace the code snippet (https://www.todomerca.ec/wp-admin/admin.php?page=edit-snippet&id=27) with the code provided below & see if it works for you.
add_filter( 'woocommerce_short_description', 'cus_woocommerce_short_description' ); function cus_woocommerce_short_description( $description ) { global $WCFM, $product, $post; $product_id = 0; $wcfm_custom_fields_values = ''; if ( is_object( $product ) && !is_product() && !get_query_var('about') ) { $product_id = $product->get_id(); $wcfm_product_custom_fields = get_option( 'wcfm_product_custom_fields', array() ); $wcfm_custom_fields_obj = new WCFMu_Custom_Field_Support(); if( $wcfm_product_custom_fields && is_array( $wcfm_product_custom_fields ) && !empty( $wcfm_product_custom_fields ) ) { foreach( $wcfm_product_custom_fields as $wpcf_index => $wcfm_product_custom_field ) { if( !isset( $wcfm_product_custom_field['enable'] ) ) continue; $display_data = $wcfm_custom_fields_obj->get_wcfm_custom_field_display_data( $product_id, $wcfm_product_custom_field ); $wcfm_custom_fields_values .= $display_data; } } } return $wcfm_custom_fields_values . $description; } - April 13, 2020 at 5:27 pm #118733
soumanta
KeymasterThe problem was because the vendor needed approval from the admin to publish a product. IF the vendor needs an approval then the user doesnt get the email notification, but if he doesnt need approval and publish his products then the user gets the notificacion. What can i do so the user gets the notification even if the vendor needs an approval from admin?
This is the case when vendor doesn’t need an approval of admin.
Step 1: Vendor adds a new product
Step 2: New product goes to “publish” status & email sent to the vendor followers.In your case, when vendor needs an approval of admin (Correct me if I am wrong)
Step 2: New product goes to “pending” status & waits for the approval of admin.
Step 3: Admin approves & publishes the vendor’s new product.When do you want to send the email to the followers of the vendor? (After “Step 2” or in “Step 3”?)
- April 14, 2020 at 12:03 am #118837
r_guayaquil
The new code snippet works perfectly. Thank you so much!
I would be great if the user gets the email notification in step 3, when the admin approves and publish the vendors new product. Will the method also works if the admin upload vendors product with csv file?
- April 14, 2020 at 5:02 am #118890
soumanta
KeymasterI would be great if the user gets the email notification in step 3, when the admin approves and publish the vendors new product. Will the method also works if the admin upload vendors product with csv file?
The above functionality is not provided by our core plugin.
add_action( 'wcfm_after_product_approve', 'wcfmu_vendors_followers_notify_after_product_approve' ); function wcfmu_vendors_followers_notify_after_product_approve( $product_id ) { global $WCFM, $WCFMu; $vendor_id = $WCFM->wcfm_vendor_support->wcfm_get_vendor_id_from_product( $product_id ); if( $vendor_id ) { if( apply_filters( 'wcfm_is_allow_followers_new_product_notification', true ) ) { $WCFMu->wcfmu_vendor_followers->wcfmu_vendors_followers_notify_on_new_product( $product_id, $vendor_id ); } } }This piece of code is only for your specific requirement & not a part of the core plugin. Please add this code as a snippet in your site & see if it works for you.(This piece of code will not work for “admin upload vendors product with csv file”)
- April 15, 2020 at 9:39 am #119257
r_guayaquil
Thank you for the code. It works perfectly.
Where can i change the text of the emails i attach? I am using loco translate but i cant find the text to translate.
Thanks for the help
You must be logged in to view attached files. - June 24, 2020 at 3:06 am #143707
musikapublishing
ParticipantHi, I’d like to add that snippet too so people get notified after a product is approved by an admin. Where do I add it please?
- June 24, 2020 at 3:19 am #143708
musikapublishing
ParticipantAlso can you please clarify where I can change the wording of the emails to followers. Thank you
- The topic ‘Followers’ is closed to new replies.
