Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Form to add product
- This topic has 1 reply, 2 voices, and was last updated 7 years, 9 months ago by
- December 4, 2018 at 4:18 pm #39021
mannino.carla
ParticipantHi! I bought WC Ultimate, I’m not sure if this form is the correct way for contact.
I have some queries:
1) I read the ACF’s guide, but when I added a custom field, this field isn’t show in new proudct form, only it shows in product page.
2) I’d like to use other form for add product. I bought WP User Frontend pro https://wedevs.com/wp-user-frontend-pro/
I’d like to use this tool in the add product link. Could you tell me how to implement that?
Thank you! - December 4, 2018 at 4:29 pm #39022
– your are not getting acf custom fields under WCFM product manager? What field type you have added?2) I’d like to use other form for add product. I bought WP User Frontend pro https://wedevs.com/wp-user-frontend-pro/
– Sorry, wcfm does not compatible with this.Well, do you know WCFM also has own custom field module?
Please check this – https://wclovers.com/knowledgebase/wcfm-custom-fields/Thank you
- The topic ‘Form to add product’ is closed to new replies.
