Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Found problem when vendor change to complete an order
- This topic has 3 replies, 2 voices, and was last updated 7 years, 1 month ago by
- July 8, 2019 at 6:04 pm #71583
Jose
I found a problem when the seller wants to use the icon to complete an order, even when it disappears, in the state, it keeps appearing in process, the same happens on the administrator’s screen.
But in the detail of the seller’s order as completed and in the administrator’s detail it appears as in process.
Regards,
You must be logged in to view attached files. - July 12, 2019 at 4:21 pm #72162
Jose
ParticipantResolved !!
The Order Sync had been deactivated.
Regards,
- July 12, 2019 at 6:45 pm #72170
Jose
ParticipantThis reply has been marked as private. - July 13, 2019 at 6:23 am #72226
The problem is that a new issue appears, if a customer orders several items from different suppliers, when a seller changes the status to completed, the customer don’t receives an email. And Admin always see the order like in process, incluide if both vendors change the order to complete.
– I think, “Order Sync” option is disabled so main order not updating as vendor update order status.
But there is notification for both Admin and Customer.
- The topic ‘Found problem when vendor change to complete an order’ is closed to new replies.
