Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Free shipping coupons do not apply.
- This topic has 20 replies, 4 voices, and was last updated 6 years, 2 months ago by
- May 15, 2019 at 11:10 pm #62343
nakedharmonix
We are trying to migrate from WCMP to the WCFM Marketplace.
But,Free shipping coupons do not apply.
http://prntscr.com/np4fz4In the case of WCMp, it worked without problems.
Do we need special settings for WCFM Marketplace?Regards,
- May 16, 2019 at 2:40 pm #62501
Which type of shipping you have created for vendor ?
Free shipping coupon only works for ZONE Shipping.
- May 17, 2019 at 2:58 am #62606
nakedharmonix
ParticipantThis reply has been marked as private. - May 18, 2019 at 12:40 pm #62796
http://prntscr.com/npmexb – What you have set “Minimum order cost” for “FREE Shipping” ? If you do not set that then set that.
Now, Free Shipping will be available in two conditions –
1. Either order cost reach that amount
2. Or, when you will apply a Free Shipping Coupon**** Vendor shipping does not work by Admin shipping setting.
- May 18, 2019 at 8:55 pm #62883
nakedharmonix
My settings seem to be fine.
But the problem is not solved.
Free shipping Even though the coupon is not adapted, it will be free shipping.>http://prntscr.com/npmexb – What you have set “Minimum order cost” for “FREE Shipping” ?
If you do not set that then set that.I set it.
https://prnt.sc/nqbzl0>Now, Free Shipping will be available in two conditions –
https://prnt.sc/nqbzl0>2. Or, when you will apply a Free Shipping Coupon
>**** Vendor shipping does not work by Admin shipping setting.This setting can not be set by the vendor shipping setting.
It can only be set by Admin shipping setting. - May 21, 2019 at 6:07 am #63133
ing.rapparini
ParticipantIt doesn’t work for me either…
- May 22, 2019 at 12:23 pm #63333
Well, it’s pretty simple. Please check this – https://www.loom.com/share/f3ee84b46f9447029f54e2e25cda1d59
- May 22, 2019 at 11:43 pm #63390
nakedharmonix
Thank you for your polite explanation.But…
Why is “minimum order amount for free shipping” required?
We do not want to use the “minimum order amount for free shipping” and the “Free shipping coupons” by default.If it is required for coupons setting, we will need to choose to show or hide it on the cart.
Regards,
- May 23, 2019 at 4:52 am #63414
– It’s not essential. But Free Shipping can be setup on the basis of this condition as well.
- May 23, 2019 at 6:38 am #63435
nakedharmonix
If no need set “minimum order amount for free shipping”, how can I set shipping free coupons?
If set” Edit Shipping Methods” as below, all will be “free shipping”.
Setting
http://prntscr.com/ns7dfu
Cart
http://prntscr.com/ns7emo - May 25, 2019 at 7:50 am #63690
ing.rapparini
ParticipantYES…NAKEDHARMONIX IS RIGHT….
it does not work if I don’t set a minimum amount….
absurd……. - May 25, 2019 at 10:50 am #63712
ing.rapparini
ParticipantMoreover I need a coupon that can be applied to any destination! Not to a specific location!
- May 26, 2019 at 5:03 pm #63853
Coupon are not depend on location.
http://prntscr.com/ns7dfu – with this setting “Minimum Order amount for free Shipping” consider “0”
- May 26, 2019 at 11:27 pm #63915
nakedharmonix
I have reported to you before…
All products will be Free Shipping.
Even if it does not apply Free Shipping coupons. - May 28, 2019 at 6:52 pm #64150
Memberhttp://prntscr.com/ns7dfu – with this setting “Minimum Order amount for free Shipping” consider “0”
All products will be Free Shipping.– Yeah right, it’s require.
- May 28, 2019 at 8:18 pm #64175
nakedharmonix
We are confused.
Your response is inconsistent.■1
Q:Why is “minimum order amount for free shipping” required?A:– It’s not essential. But Free Shipping can be setup on the basis of this condition as well.
■2
Q:http://prntscr.com/ns7dfu – with this setting “Minimum Order amount for free Shipping” consider “0”
All products will be Free Shipping.A:– Yeah right, it’s require.
Which one is correct?
Woocommerce’s default free shipping coupon feature is not required to be used with “minimum order amount for free shipping”.
So,We do not require a combination of “free shipping minimum order value” and “free shipping coupon”. - May 29, 2019 at 7:26 pm #64860
Sorry for the confusion!
If you are setting up “Free Shipping” method then “Minimum Order amount” is essential, otherwise “0” will be consider as “Minimum Order amount” to apply Free Shipping.
Then only Free Shipping option will be visible at Cart and Checkout.
- May 31, 2019 at 10:29 pm #65334
macnomo
ParticipantHey Guys!
Free Shipping Coupons has to be setted to Fixed Discount for product, otherwhise won’t work. Do not use percentage.
Now!!! Why is that if it’s a Free Shipping Coupon it showes “0” in the description? and the description should say FREE SHIPPING, not what kind of disccount. That should be fixed. Customers don’t want to see that, it’s confusing!
See Attachment.By the way, my coupons doesn’t show on store!! and YES is checked to be shown on store.
You must be logged in to view attached files. - June 2, 2019 at 4:53 pm #65547
– We will definitely take care of this in next update.
– Then how you get this attachment screenshot ?
- June 7, 2019 at 1:08 am #66329
macnomo
Thanks for the update, now it doesn’t show the “0”
About the screenshot: I added the coupon to the side bar widget, is not on the store as it should be.
- June 10, 2019 at 8:45 pm #66836
– This will be visible to only that particular store sidebar with which coupon is associated.
- The topic ‘Free shipping coupons do not apply.’ is closed to new replies.
