Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Full Translation with Loco
Tagged: english, loco, portuguese, string, Translate, Translation
- This topic has 6 replies, 2 voices, and was last updated 5 years, 6 months ago by
- January 16, 2020 at 3:28 am #102228
contatoapp
ParticipantHello. I’ve used Loco Translate to translate several string to portuguese but it seems some elements are left out. There are a couple which I can’t find to translate at all and some that even though I thought might’ve applied, it didn’t.
For example, the “Reject” button on the Withdrawal Request panel. I found the string to Approve but not the one to Reject.
It also seems that most strings are automatically translated and that I also cannot find under Loco. Some are translated separately but mixed together. For example the “Vendors Panel”, which mixes the “Sold By Label” and another string.
Is there a more intuitive way to figure out all of these strings to be translated, or is Loco still the best way?
You must be logged in to view attached files. - January 30, 2020 at 6:33 pm #104687
KeymasterHello,
Thanks for getting in touch and sorry for any inconvenience caused.
The string ‘Reject’ is in “WCFM WooCommerce Frontend Manager” plugin. Please refer to the following images – [Settings] https://ibb.co/0jGKJS9 , [Result] https://ibb.co/xMdPD9L
Loco is still the easiest way to achieve any kind of string translation.
Thanks - January 30, 2020 at 6:51 pm #104698
contatoapp
ParticipantHello. As you can see in the attached picture, there are no strings for the “Reject” button.
You must be logged in to view attached files. - January 30, 2020 at 7:20 pm #104702
KeymasterHello,
Kindly press the Sync button and then try searching for the string ‘Reject’. This is a known issue for Loco. So, it’s always safe to Sync the list first.
Thanks - February 4, 2020 at 1:29 am #105252
contatoapp
ParticipantHello. I had not realized the purpose of that button. It works perfectly now, thank you!
- February 4, 2020 at 2:24 am #105268
contatoapp
ParticipantHi.
Even though I managed to find the strings I’ve mentioned earlier, there are some still missing. For example, the final button for the Store Vendor Setup. Also, the shipping address on the vendor dashboard (Endereço 1 and Endereço 2 are automatically translated from Address 1 and 2, respectively, and I can’t either find these specific strings or it doesn’t apply to them).
You must be logged in to view attached files. - February 4, 2020 at 10:26 pm #105442
Those two translations are already there in the Portuguese (Brazil) translation file. See the attached image.
The second image you attached (may be related to “the final button for the Store Vendor Setup.”), was mistakenly deleted. Can you please send that again.
Thanks!Attachments:
