Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Funtion on wc appointments backend dont showed on wcfm front
Tagged: appointments, backend, frontend, grant download access to file
- This topic has 3 replies, 2 voices, and was last updated 7 years ago by
- January 14, 2019 at 2:53 pm #43465
joaquin.carretero
Participanthi,
A funtion that is showed on WC appointments backend, that i need for granting access to an archive after an order completed (paid), is unreacheable in the wcfm ultimate front.
I attach a file of the problem, the user experience in WC appointments and WCFM ultimate. Permisos de archivo descargable(spanish) = grant download access to file (english)
Additionally i need to change the “create appointment” and some other strings on WCFM U for translation purposethanks in advance
You must be logged in to view attached files. - January 15, 2019 at 5:44 am #43571
Well, I understand your requirement.
But, download permission is mainly comes for “Downloadable Products” and WC auto generate this as order mark completed.
Due you want to have this option for “Appointable Products”?
“Additionally i need to change the “create appointment” and some other strings on WCFM U for translation purpose”
– Please use Loco Translate plugin for the purposeThank You
- January 15, 2019 at 11:55 am #43683
joaquin.carretero
Participant“Due you want to have this option for “Appointable Products”?”
A form will fill a pdf document for every visit, to make records of a treatment, based on the appointments
- January 16, 2019 at 6:14 am #43793
“A form will fill a pdf document for every visit, to make records of a treatment, based on the appointments”
– OK, but that can not be fulfill using that option. That is for downloadable products.
Between, who will filled up this PDF document and what will happen to this?
Do you have any form like this and PDF generation code implemented?Thank You
- The topic ‘Funtion on wc appointments backend dont showed on wcfm front’ is closed to new replies.
