01Day 13Hr 18Min 11Sec
Geo location for product not working
Viewing 7 reply threads
    • #127206
      arshad.yusofff
      Hi, I have enable geo location for product but when I search the product in the area, no products were found. Do the product location follow the vendor address?
    • #127306
      Keymaster
      Yes, you are right! All products uses location of their vendor store. If you want to set different location for each product then you will need to use Geo my WP plugin. Also, you will require to add a search form, as GEO my WP doesn’t work with your default store search. Follow this tutorial to get the idea – http://docsdep.geomywp.com/create-a-search-form/
      I hope this answers your question.
    • #127309
      Yes, Product location search depends on Vendor’s shop location.
    • #127319
      arshad.yusofff
      I’ve already set the vendor location but there is still no product available when i’m using the map filter. can you have a look at my site?
      • #127398
        Please share us your Page url, we can check your site and guide you accordingly.
    • #127823
      arshad.yusofff
    • #128064
      arshad.yusofff
      Hi, have you got any chance to check my site?
    • #128081
      Auhouse.ru
      Hi, the card does not work on the supplier list page and on the store page, nothing is displayed on it
      Site Auhouse.ru
    • #130474
      gabriele.fortunato
      Good Morning,
      I am experiencing same issue of Geolocation not showing the products, even if the store is in the range (and on the map). This happens for all the products for which the Vendor has done “Add to My Store”.
      Is it possible to have the Geolocation showing also those products for the stores in the radius ?
