Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Gravity Forms integration
- This topic has 5 replies, 2 voices, and was last updated 6 years, 8 months ago by
- January 1, 2019 at 4:19 am #41862
napesdownunder
Participanthi
I am attempting to use Gravity Forms to build my own Front End submission form to post products onto Woocommerce, as an ‘auction’ product type.However, I am getting stuck on the custom post meta names. Can you assist me with this one?
I can get Gravity Forms to post to all fields for the plugin ‘Woo Commerce Simple Auctions’ but it just won’t go live. I then have to go into the ‘back end’ of Woo Commerce, into the product and push ‘update’ for it to actually become active.
Todd - January 1, 2019 at 3:00 pm #41914
Well, WCFM not yet compatible with Gravity Forms.
Between, Gravity Forms allow addition fields before adding a product to cart.
Why you are not using WC Product Addons for the purpose (https://woocommerce.com/products/product-add-ons/)?
- January 1, 2019 at 5:00 pm #41934
napesdownunder
ParticipantUmmmm….not using WC Product Addons because it has nothing to do with my issue and I Have no use for it
- January 1, 2019 at 5:34 pm #41935
Can you please show me some screenshots, how you are using Gravity Forms for your purpose?
Well, as I know – using Gravity Forms possible to associate a form with product and form inputs submitted with order. Also possible to add additional cost as per selected options.
Are you doing something different!
- January 1, 2019 at 5:58 pm #41944
napesdownunder
ParticipantI am only using WCFM to support multiple vendors. I am creating a very unique Gravity Form to launch an auction into Woo Commerce.
The front end WCFM form does not do what I need it to.
- January 2, 2019 at 4:45 am #41969
Can you show me screenshot for this?
I am not getting clue for this.
Well, if you are not comfortable to share in public forum then please mail me directly at – wclovers.custom@gmail.com
- The topic ‘Gravity Forms integration’ is closed to new replies.
