Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Bookings › Has Person and Has Resources losing check status
- This topic has 4 replies, 3 voices, and was last updated 6 years, 10 months ago by
- May 24, 2019 at 6:35 pm #63638
Bernard
GuestHas Person and Has Resources losing check status when saving. They do store value – they just seem not to be loading value.
Is this a bug?
B - May 24, 2019 at 6:51 pm #63639
Bernard
GuestAnd the Can be cancelled too.
thanks - May 27, 2019 at 7:48 am #63948
Are you using WCFM Free only ? If so, then WCFM has no support of Booking Person and Resources.
These are come with WCFM Ultimate (https://wclovers.com/product/woocommerce-frontend-manager-ultimate/).
Look I have just created a Booking product using Person Type and Resource – https://www.loom.com/share/8c94fa5fcea24e30a0f84b28d7d2ae2e
- May 29, 2019 at 7:03 am #64217
FuBendu
ParticipantI discovered what the problem is. I have your paid plugin.
I am using the Booking Accommodation (free Woocommerce in addition to the Booking plugin). I realised that when I set the product type to “Accommodation product” all checkboxes stop working. Otherwise, all seems to works fine.
I can understand that this is not a supported extension – but I think you are super close to making this compatible since this is a mere small tweak by Woocommemrce to Bookings to make it more suitable for accomodation.
Many thanks
B - May 31, 2019 at 6:29 pm #65218
WCFM compatible with Accommodation addon.
OK, we are checking this. But possible Accommodation not yet compatible with latest WC Bookings plugin.
- The topic ‘Has Person and Has Resources losing check status’ is closed to new replies.
