Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Hide archived products in vendor store
- This topic has 6 replies, 5 voices, and was last updated 6 years ago by
CommunityCorals.
- December 31, 2019 at 4:20 pm #100225
CommunityCorals
my vendors have to use archive as I have deactivated “delete” functionality. Vendors are very confused that archived products are still visible in their vendor store thoug ( even if it is just them that see the product).
Is it possible to hide archived products in vendor store?
Domininique - December 31, 2019 at 10:02 pm #100276
badianafaa
ParticipantThis reply has been marked as private. - January 7, 2020 at 2:11 am #101171
Aipoke
ParticipantThis would also interest me. Please share
- January 7, 2020 at 3:54 am #101175
Craig
ParticipantThis would be an interesting feature but would require the vendor the ability to toggle the visibility on or off of the archived listings.
If you simply just hide the archived listings then then why not delete them for the start? Or are you wanting to keep them in the “system” for historical reporting purposes?
- January 8, 2020 at 4:16 pm #101355
CommunityCorals
ParticipantIf you simply just hide the archived listings then then why not delete them for the start? Or are you wanting to keep them in the “system” for historical reporting purposes?
Hi, I would like to keep the page of the product to keep it listed in google and not create 404 error which google doesn´t like.
BR
Dominique - January 20, 2020 at 10:17 pm #102886
Jamie O’Reilly
ParticipantHi Dominique
Just wondered if you made any progress with this query? We are looking for a solution to this too. We would like archived products to be visible when someone clicks on the url – so not a broken link and good for SEO. However, we do not want the archived products to continue to be listed in the front-end of the vendor’s store or in category or other product listings. It should only be visible in the front end as a single product page and of course through the back end like all other products.
Jamie
- January 24, 2020 at 6:41 pm #103629
CommunityCorals
ParticipantHi, so far I haven´t received any reply.
As it currently is an archived product is not visible to the customer on fromtend. Just as single product page from search engines. This is a good thing.
The archived products are visible in vendor store for the vendor though. This leads to several confusion for the vendor why the products are still available and so on.
BR
DOminique
