Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Hide Shipping tab from settings
- This topic has 4 replies, 2 voices, and was last updated 6 years, 1 month ago by
- November 11, 2019 at 5:10 pm #91802
Jamie O’Reilly
ParticipantHi there Vendors are using per product shipping which they access through the shipping settings in ther products section. So to avoid confusion I’d like to hide the Shipping tab in the Settings section so they only have one place to add their shipping info to.
Can you give me a filter please?
Thank you - November 11, 2019 at 5:42 pm #91818
KeymasterThere is a settings for that. Go to Capability menu from your admin dashboard and disable ‘Shipping’ under ‘Panels’ section. See image https://ibb.co/Dbgm1tY
- November 11, 2019 at 8:08 pm #91851
Jamie O’Reilly
ParticipantAh thank you – the thing is that we need them to be able to access the shipping settings in the per product shipping and they won’t be able to do this is I switch it off in panels. Thanks for the idea though
- November 11, 2019 at 8:32 pm #91852
Jamie O’Reilly
ParticipantSo to be clear shipping by zones will be selected at admin level but invisible to vendors who will only see per product shipping in their products shipping section. Is there some code for this please? Thank you
- November 12, 2019 at 5:34 pm #91991
KeymasterSorry I misunderstood your query. Add this code to your child theme’s functions.php
add_filter('wcfm_is_allow_vshipping_settings', '__return_false');
- The topic ‘Hide Shipping tab from settings’ is closed to new replies.
