Durga Puja
01Day 10Hr 18Min 25Sec
Durga Puja
Hiding some specific fields and translations
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Hiding some specific fields and translations
Viewing 10 reply threads
    • #135005
      Yourcarfinder
      I’ve used Loco translate to change a good portion of WCFM’s text however there is a fairly large number of text that i can’t find.
      The entire dashboard “Settings” where you enter Email, Phone, Logo, Banner etc i’ve been unable to translate.
      On the register page “Store Phone”
      “Store” within the settings menu-name
      Within the settings-menu i would like to hide SEO and Customer support items.
      This last one i don’t know if you can help or not. I’m using the Ultimate Woo commerce plug-in to add auctions to WCFM and i’m wondering if there are some snipptes to hide the fields in the auction data tab?
      Depending on some things i need to either hide the whole “Auction data” tab or the fields that data is input (See screen shot)
    • #135029
      Yourcarfinder
      I found the labels for the dashboard in the .php files and have successfully changed them but from my understanding these will be undone everytime the plugin updates. I wish i knew more about how snippets code works but my main skill set is around design and not code.
    • #135033
      >> Try the below code in your theme’s functions.php –
      add_filter('wcfm_marketplace_settings_fields_general','wcfm_marketplace_translate_settings_fields_general',10,2);
      function wcfm_marketplace_translate_settings_fields_general($fields, $user_id) {
      	$fields['store_email']['label'] = 'Storez Email';
      	$fields['phone']['label'] = 'Storez phone';
      	$fields['gravatar']['label'] = 'Storez Logo';
      	$fields['banner']['label'] = 'Storez banner';
      	$fields['banner_type']['label'] = 'Storez banner type';
      	return $fields;
      add_filter('wcfm_marketplace_settings_fields_brand','wcfm_marketplace_translate_brand_settings_fields_general',10,2);
      function wcfm_marketplace_translate_brand_settings_fields_general($fields, $user_id) {
      	return $fields;
      >>For this –
      add_filter('wcfm_membership_registration_fields_phone','wcfm_marketplace_translate_registration_fields_phone',10);
      function wcfm_marketplace_translate_registration_fields_phone($fields) {
      	$fields['user_phone']['label'] = 'Storez Phone';
      	return $fields;
      >>For this you need to translate from LOCO translate,
      WP dashboard -> Loco translate ->plugins -> WCFM – WooCommerce Frontend Manager -> select your site language -> search string “Store” and translate -> save
      >>To hide “SEO” and “customer support” from vendor settings –
      turn off the “SEO” and “Customer Support” capability. (PFA)
      To hide “Auction data” tab, it’s also managed by capability.(WCFM dashboard-> Capability). Turn off the “Auction” capability.
    • #135048
      Yourcarfinder
      Hi thanks for the reply,
      the register page code did not work see link: https://yourcarfinder.co.uk/sellyourcar/
      The dashboard label codes worked thanks.. i maybe able to figure out the rest of the fields based on this
      “To hide “Auction data” tab, it’s also managed by capability.(WCFM dashboard-> Capability). Turn off the “Auction” capability.”
      If i do that i turns of auctions which is not what i want.. basically out site only needs the ability for the “vendor” to Add in a title, description and images then hit submit and our buyers will then bid on their listing, and since it is for Cars all the bids will be based on Car Value + any extra the buyer is willing to pay. So hiding the field and using default values is the best way for the sellers to list cars for bid. Although the starting value from “empty” to 0 is another matter i’m trying to solve but i don’t think that is WCFM’s code but the plugin or woocomerce itself?.
    • #135107
      Okay! hide auction tab –
      Try this code –
      add_action('init',function(){
      	global $WCFM, $WCFMmp, $WCFMu;
      	remove_filter('after_wcfm_products_manage_general', array( $WCFMu->wcfmu_integrations, 'wcfm_yithauction_product_manage_fields' ), 70, 2 );
      	remove_filter('after_wcfm_products_manage_general', array( $WCFMu->wcfmu_integrations, 'wcfm_wcsauction_product_manage_fields' ), 70, 2 );
      regarding the register page code did not work see link: https://yourcarfinder.co.uk/sellyourcar/
      >>Try this –
      	$fields['phone']['label'] = 'Storez Phone';
      	return $fields;
    • #135335
      Yourcarfinder
      The register page wording as updated thanks.
      The code to hide the auction tab did not work, i am using Woo Ultimate Auctions plug-in (https://auctionplugin.net/) and i could not find any code related to it within the integrations.php so i’m not sure if that method can hide it.
    • #135359
      Yes, you are right.
      As of now we have https://yithemes.com/themes/plugins/yith-woocommerce-auctions/ and https://codecanyon.net/item/woocommerce-simple-auctions-wordpress-auctions/6811382 auction plugin support. (https://wclovers.com/wcfm-compatible-plugins/)
      So you can hide this section using css.
      If you unable to hide this section using css, you can provide us the link with temporary access(Set as private reply), then we can guide you accordingly.
    • #135441
      Yourcarfinder
    • #135451
      Yourcarfinder
    • #135462
      We have removed this “Auction tab” using below code-
      	remove_filter('wcfm_product_type_default_tab', 'uwa_vendor_support_default_tab');
      add_filter( 'wcfm_product_manage_fields_auction_options', function( $options, $product_id,$auction_product ) {
        $options['woo_ua_opening_price']['attributes']['data-required'] = 0;
        return $options;
      }, 50, 3 );
      Please be advise for further queries regarding auction contact with the “Ultimate WooCommerce Auction Pro-Business ” plugin support. The plugin has added our WCFM support.
      • #135468
        Yourcarfinder
        Thanks alot 😀
        This is perfect and you added in the default value for opening price snippet so that it works
        Thank you very much
      • #135470
        Yourcarfinder
        The code however does not seem to work on my other site
        where any changes made to any php files directly in the website files?
        • #135511
          We have also added css –
          div#wcfm_products_manage_form_auction_options_head {
          	display:none !important;
    • #138306
      hd
      i have a simple question, you wrote that its possible tohide seo and customer support via capabilities.
      I cant see this switch at capabilies of WCMF, which plugin or edition is it?
      Groups&Staff? or Ultimate? or something else?
      Thank you and kind regards
      HD
  • The topic ‘Hiding some specific fields and translations’ is closed to new replies.
