Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Analytics › Hits showing from wrong country
- This topic has 14 replies, 2 voices, and was last updated 6 years, 10 months ago by
- October 17, 2018 at 5:54 pm #34232
jhweb
ParticipantHi, I have purchased the analytics plugin and for some reason it is showing a majority of hits from the US and zero from the UK. We are UK based with much of our customer base located in the UK. Am I doing something wrong with the setup?
JonAttachments:
You must be logged in to view attached files. - October 19, 2018 at 8:23 pm #34371
Umm … actually it has no setup for the purpose and it shows data as per customers visit.
Well, it has a setting to choose preferred region, can you please set UK over there and take a look what it’s showing?
Between, is your site has connected with Google Analytics?
If not, then please connect and check traffic source in Google console for cross check.
May use this plugin for the purpose – https://wordpress.org/plugins/google-analytics-for-wordpress/Thank You
- October 20, 2018 at 8:23 pm #34465
jhweb
ParticipantI’ve changed the preferred region to UK and it shows zero hits.. I’ve attached a screenshot of the world map and as you can see a majrity of the hits are from the US with none from the UK. Which is actually impossible as we are UK based and every vendor is UK based.
You must be logged in to view attached files. - October 20, 2018 at 8:24 pm #34467
- October 21, 2018 at 6:48 am #34485
MemberGreat 🙂
Please re-check this with Google Analytics as well.
- October 21, 2018 at 9:12 am #34496
- October 21, 2018 at 9:42 am #34507
WCFM Analytics is no way link to Google Analytics as it does not support vendor wise analytics.
For main site you may use Google Analytics and check stats using this plugin – https://wordpress.org/plugins/google-analytics-for-wordpress/
- October 21, 2018 at 10:53 pm #34549
- October 22, 2018 at 6:10 am #34571
Can you allow me to check this once in your site?
- October 22, 2018 at 7:17 am #34574
Site access not required.
We got the issue, will resolve in next update.
- October 22, 2018 at 8:18 am #34575
jhweb
ParticipantExcellent, thank you. Do you have an ETA of the next update. So I can inform the vendors who are querying 🙂
- October 22, 2018 at 10:37 am #34582
We are just waiting for WC 3.5 which will be release tomorrow.
We will update just after that.Thank You
- October 24, 2018 at 1:50 pm #34747
WCFM Analytics in version has just released.
- October 25, 2018 at 1:05 pm #34952
jhweb
ParticipantYes all working fine now.
Thanks 🙂 - October 25, 2018 at 4:58 pm #34973
- The topic ‘Hits showing from wrong country’ is closed to new replies.
