Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WC Vendors › How can I hide sub-orders?
- This topic has 3 replies, 2 voices, and was last updated 6 years, 7 months ago by WCFM Forum.
- May 30, 2018 at 5:38 am #24002AlexGuest
Hello!
I use wc-marketplace vendors.
Every time I get an order, there is 2 orders in the vendor dashboard.
here is a screenshot:
https://snag.gy/PhR40k.jpgin wc-marketplace vendors dashboard I see only one order, in you dashboard I see two duplicate orders.
How I can cancel the duplicate orders that are created (one for the store and one for the vendor)
Please help.
- May 30, 2018 at 8:02 am #24009WCFM ForumMember
I am really confused.
1. WC Marketplace has no concept of generating “Sub-Order”
2. Only Dokan Multi-vendor has concept of sub-order– now, which one you are using?
From screenshot, it’s seems two orders as Order ID is different.
Please check the things again, I think there has some misunderstanding.
Well, if you had Dokan before and now youhave changed to WC Marketplace then delete all old orders, otherwise you will be in big trouble.
- May 30, 2018 at 8:50 am #24015AlexGuest
Thanks for the prompt reply!
I use only wc marketplace.
When I use the default wc-marketplace vendor dashboard it show only one order per each
this is a fresh order in woocommerce panel with a sub order:
https://snag.gy/yqKd9Q.jpgand this is what I get in your panel for this order:
https://snag.gy/6wmLf0.jpgWhen I switch to the WC-marketplace vendor panel I see only one order – the main order.
Please advice.
Thanks a lot for the help. - May 30, 2018 at 10:36 am #24016WCFM ForumMember
Well, WC Marketplace does not have any sub-order concept by default.
Are you using any custom plugin for this?
- The topic ‘How can I hide sub-orders?’ is closed to new replies.
