Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › How can i save store location at Store Settings
- This topic has 5 replies, 3 voices, and was last updated 7 years, 7 months ago by
- March 21, 2019 at 12:02 pm #53822
leehuijie777
ParticipantI entered the address and updated the store settings.
But i can not find the address data as attached image.
and also can not find on the google map on the store location.Attachments:
You must be logged in to view attached files. - March 21, 2019 at 8:50 pm #53882
Craig
ParticipantHave you activated and entered your Google Map API Key in your Admin Dashboard settings?
I think you may need that.
- March 21, 2019 at 11:46 pm #53904
leehuijie777
ParticipantThank you for your attention.
Of course I entered Google Map API Key as you see on attached image.
On previous systems, this Google Map worked fine, but after I erased the all plugins and installed it again, then it did not work.
In the marketplace, the google api is normally registered and can be seen in google traffic.
The ‘find location’ entered in the vendor’s store location is not saved and the location does not appear on the map.
Where’s the problem?
please help me.Attachments:
You must be logged in to view attached files. - March 21, 2019 at 11:49 pm #53906
Craig
ParticipantYour first attachment gave no indication of you activating your API key. That is what I asked.
I’m a WC Lovers customer not a WC lovers support person and just try to offer help as your first message did not provide very much detail.
- March 21, 2019 at 11:58 pm #53907
leehuijie777
ParticipantThank you!…
Solved… It’s fine after update latest WooCommerce Multivendor Marketplace plugin… - March 22, 2019 at 8:53 am #53958
MemberRight, there was an issue, we have resolved this in latest update.
Store List Radius search option also added in latest update 🙂
- The topic ‘How can i save store location at Store Settings’ is closed to new replies.
