Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › How do we charge tax on our memberships?
- This topic has 7 replies, 2 voices, and was last updated 6 years, 2 months ago by
- March 25, 2019 at 3:52 am #54384
- March 26, 2019 at 2:44 pm #54572
Well, membership cost is Tax inclusive.
It will be best, if you mention this in memebership description or in this page!
- March 26, 2019 at 10:30 pm #54693
Craig
Participantok thanks for that advice. I will do that for our plans.
If I log this in the “feature request” do you think it is possible to add the functionality to have a charge tax option? In Canada a business can write off the tax that they are charged but if the invoice does not detail that separately they have no way of knowing.
- March 28, 2019 at 11:37 am #54944
Well, we are going to add “membership Invoice” option very soon and also allow to show Tax in this.
- March 28, 2019 at 8:17 pm #55080
Craig
ParticipantOk thanks. This will require the ability to identify that tax portion in the membership settings.
The “workaround” we are doing now as adding the tax and base cost into one lump sum.
For example our $24.00 + 5% GST plan is listed as a single payment of $25.20 so the invoice would still only reflect $25.20 unless we can identify the two entities elsewhere in the membership set up.
- March 29, 2019 at 5:16 pm #55224
Don’t worry, we will add Tax option in coming Membership update.
- June 5, 2019 at 2:55 am #65944
- June 5, 2019 at 6:55 pm #66081
Yes, this feature was added in 2.5.0, you may define Tax from membership setting section – https://ibb.co/VW3JD8d
- The topic ‘How do we charge tax on our memberships?’ is closed to new replies.
