02Day 23Hr 51Min 40Sec
How the some fields of Sections work?
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › How the some fields of Sections work?
Viewing 2 reply threads
    • #27645
      MOHO
      1. Add-ons
      2. Toolset Fields
      3. ACF Fields
      4. Location
      I use toolset field and category.
      I disable these option, but the vendor also could edit these field.
      and loaction i didn’t where it display…
      Could you explain how these options work?
      By moho
    • #27736
      I know you are using “Toolset” for creating custom fields.
      “I disable these option, but the vendor also could edit these field.” – not getting this clearly! Do you want to disable Toolset fileds for your vendors? Then set OFF Toolset.
      Don’t think about other options, as you don’t have those plugins.
    • #27746
      MOHO
      OK Thanks your reply.
      I got it!
      Please close it.
  • The topic ‘How the some fields of Sections work?’ is closed to new replies.
