Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › How to edit tab/field labels
- This topic has 27 replies, 4 voices, and was last updated 7 years, 8 months ago by
- November 14, 2017 at 5:45 pm #15758
joyce
ParticipantHi, I need to edit some tabs’ names and fields’ names, can you show me the HOW?
Thanks. - November 15, 2017 at 6:49 am #15780
WCfM Forum
Just use translator for such purpose, easiest and fastest possible solution.
Translate in WP default language (english) using Loco Translate.
Please know ke if you required any further assistance regarding this.
- November 15, 2017 at 6:59 am #15781
joyce
ParticipantHi, i mean on your WCfM-U’s interface, for instance, I would want to change
– the tab “PRODUCTS” to “SPACE LISTINGS”
– the tab “RENTALS” to “BOOKING CALENDAR”
– the tab “VENDORS” to “SPACE OWNERS”Thanks.
- November 15, 2017 at 8:44 am #15782
Simha
Yeah, all are possible. Just translate default in default language.
- November 15, 2017 at 12:55 pm #15793
joyce
Yes, it works, thanks so much.
In addition, I need to add tooltip after a field input, such as after the Logo. - November 15, 2017 at 2:13 pm #15794
Simha
Wow .. great to know that it resolved your issue.
Help text – That’s also possible but using some coding.
Don’t worry, we will do that for you.
You just have to send us – list of fields with screen name and help text.
- November 15, 2017 at 4:55 pm #15797
joyce
ParticipantThis reply has been marked as private. - November 15, 2017 at 5:00 pm #15798
joyce
One more thing, I need to widen the menu panel (tab) on the left slightly, which file should I amend?
- November 16, 2017 at 5:07 am #15809
Shhiv Narayan
Thanks for the list, we will do that but no access was required.
Menu widen is only possible through CSS and best to do so from your child theme style.css.
Please never edit WCFM any core files then you can’t able to update regularly.Thank You
- November 16, 2017 at 4:21 pm #15829
joyce
ParticipantThis reply has been marked as private. - November 16, 2017 at 4:36 pm #15830
joyce
ParticipantHi, I still got one more issue with WCfM-U, I’m using the RnB Rental & Bookings Plugin for the time-based booking, but the inventory doesn’t seem to be entirely linked to RnB plugin, coz the Availability Management section is missing…
- November 17, 2017 at 4:23 pm #15848
Sinha
Thanks for the credentials, I will add those Custom code in your site.
Enquiry already has all those, possibly you have tried as a logged in user. It’s form exactly same as review form.
We didn’t disclose email to Vendors but they can see name of that user, isn’t enough!
- November 17, 2017 at 4:32 pm #15849
joyce
Thanks for the update and I will try out the enquiry feature again.
As well, thanks for helping me out on the customization.Can I hide a menu tab from vendors, for instance, the Quotes menu?
- November 18, 2017 at 9:46 am #15861
Simha
Thanks for your understanding. Please check the things in your own way and feel free to reach us for any assistance.
I am afraid to say that there is no such settings to disable Quote menu.
Are you going to disable this feature for RNB plugin or just don’t want to have this under vendors’ dashboard?
We will help to achieve this in both the way, don’t worry!
- November 18, 2017 at 10:34 am #15862
joyce
I have disabled the Quote feature in RnB settings but it’s sill showing in WCFM, I just need to hide the Quote menu tab from WCFM then vendors won’t access it. Possible?
In addition, are you or your team accessing my website or server (via ftp)? coz my site has been down since late last night (UTC+8)…
- November 19, 2017 at 10:57 pm #15883
We didn’t yet touch your website., either FTP or wp-admin.
Better you please reset passwords, we don’t require any access.
We will send you custom code as a separate add-on and you just have to install that in your site.Between, which multi-vendor plugin your are using is?
- November 20, 2017 at 7:29 am #15901
joyce
Thanks for responding back.
I will reset the passwords for FTP & wp admin.
I’m using WC Marketplace as the multi-vendor plugin.
- November 21, 2017 at 5:26 am #15916
Here is the custom code for you.
Kindly download and install this plugin to your site.This will add setting help texts and will remove “Quotes” menu.
You must be logged in to view attached files. - November 21, 2017 at 9:38 am #15920
joyce
Thanks for the custom codes, really appreciate your help.
I just installed it and also tested it on mobile, found these issues:
1. These content tabs (menu tabs) aren’t responsive on mobile, Home, Products, Orders, Payments, Reports, the right side got cut off, pls refer to the screenshot
2. Can I centralize the PAYOR logo on the left panel?
3. Under the inventory management, there’s a section missing, Availability Management, there’s no selection at WCFM…Thanks.
You must be logged in to view attached files. - November 22, 2017 at 7:27 am #15937
We don’t have such availability option in Back-end even.
Are you using any other add-on for this?Kindly check our demo as Admin (http://wcrental.wcfmdemos.com/my-account, UL: demo_admin, PW: demo_admin), is any settings missing?
We are happy to add those but have to get those options.
Responsive issue will be taken care off in next update.
- November 22, 2017 at 8:01 am #15938
joyce
I’m using RnB rental & booking system, the latest version, I think yours is old version, which the availability is still attached to the main product settings.
When will be the next update? coz I need to have it responsive, that’s the baseline. I’m gonna remove the custom code from my site first.
- November 22, 2017 at 9:38 am #15946
Simha
We have RNB Bookinging 5.0.1, do you have any further updated verions?
If yes, is this possible for you to share that with us.We have already updat code in wordpress.org but didn’t change version yet, you can have those now but then you have to delete and reinstall WCfM Free once.
Between, WCfM new version will be there possibly by tomorrow.
- November 22, 2017 at 3:59 pm #15965
joyce
My RnB version is also 5.0.1, in this version the date availability is controlled under the Inventory tab which the inventory will be created automatically after the product is successfully submitted and approved, then admin can control the unavailable dates there (which is a very crucial feature for bookings). After I used the WCFM, this feature isn’t available in WCFM, are you guys still working on the full integration to RnB?
For the responsive issue, I’ll wait for the version update. Looking forward to it.
Thanks for the help.
- November 23, 2017 at 5:32 am #15997
WCFM 3.3.1 has already released, kindly update yours and take a look for those responsive issues.
We are not working on RnB integration any more, but I mentioned if they had added any new features in latest versions then we are happy to integrate those as well.
This is our Rnb demo as Admin (http://wcrental.wcfmdemos.com/my-account, UL: demo_admin, PW: demo_admin), please check once if we are missing something, as we don’t have such options in wp-admin backend either.
just to mention, as I remember RnB has such options in their free version.
Please help us a bit to find those settings in our demo setup.
Thanks for your cooperation and patience.
- December 2, 2017 at 1:46 pm #16429
joyce
ParticipantThis reply has been marked as private. - December 2, 2017 at 1:50 pm #16434
joyce
ParticipantThis reply has been marked as private. - December 6, 2017 at 10:24 am #16577
Sorry for the delayed response.
1. Really thanks for your such detailed response, we are looking into this and will Availability Management part in next update be sure.
2. Yeah sure, we will test this also and if there is any such issues then will fix definitely.
3. Map is not using custom field. You have to use a Map plugin addon for that. Please check this once to get better understanding – https://wclovers.com/blog/location-products-wcfm/
4. Actually, we can set any hard code size or help text for that as it looks different in different themes. Just tell me your preferred help texts and we will add those for you.
5. Those are not customization from us, from a third party plugin – https://codecanyon.net/item/woocommerce-vehicle-parts-finder-yearmakemodelenginecategorykeyword/15122009
- December 6, 2017 at 11:41 pm #16601
WCFM new version has just released, it’s coming up with Rental & Booking inventory availability manager.
kindly update yours and take a look.We have also checked,Opening & closing time saving working fine.
- The topic ‘How to edit tab/field labels’ is closed to new replies.
