How To Restrict product or category based on membership level ?
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › How To Restrict product or category based on membership level ?
Viewing 5 reply threads
    • #36127
      Dan
      Is there a way to restrict any product or category from certain member levels ? I am using Free plugin ?
      2. Can I use marketplace plugin with another membership plugin ?
    • #36130
      First of all, there is no such membership plugin which supports vendor.
      Well, you may off course such capabilities for vendors using WCFM Ultimate.
      But if you want to setup this for membership levels then WCFM Groups & Staffs also required.
      Check this video – https://youtu.be/pO4_9xEzWic
    • #36295
      Dan
      Will Vendor with membership A be shown a message to upgrade his membership to view restricted category ? Will add to cart button be removed or how will it work ?
    • #36305
      Vendors are allow to upgrade membership from their profile page -> membership
      Between, category there is no message but they will see message if product limit reached and show them membership upgrade option.
    • #37160
      Dan
      Hi8,
      I’m still not 100% clear on this.
      If I have a free membership plan and a premium monthly plan.
      I want to restrict access to a certain category only reserved for Premium membership.
      There is a page where premium products and free are toggled on a pricing table visible to all users with link to product. If free member clicks the premium table I need him to see message to either upgrade or the add to cart button must be hidden ?
    • #37166
      “I want to restrict access to a certain category only reserved for Premium membership.”
      – This possible to achieve using WCFM Ultimate and WCFM Groups & Staffs
      You may create restriction for all these – https://ibb.co/nHQZ0L
      “There is a page where premium products and free are toggled on a pricing table visible to all users with link to product. If free member clicks the premium table I need him to see message to either upgrade or the add to cart button must be hidden ?”
      – You may off course create such pricing table using any plugin. Just use WCFM membership subscription button short code there. https://ibb.co/hx0dS0
  • The topic ‘How To Restrict product or category based on membership level ?’ is closed to new replies.
