Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › How to translate Local Pickup/Pickup from store?
- This topic has 5 replies, 4 voices, and was last updated 5 years, 10 months ago by
Henriette.
- April 23, 2020 at 3:55 pm #122170
Henriette
I can’t thank you enough for the new option vendor has now to enable Local Pickup options.
I tried it immediately after update and it works like a charm!My only problem is that I can’t find where to translate it in my language.
I can not find it in the Language files.
Would you please be so kind to point me in the right direction?Thank you.
You must be logged in to view attached files. - April 23, 2020 at 3:59 pm #122172
SebastianFloKa
Participantloco translate / wc-multivendor-marketplace_your language –> press sync button –> search for pickup
and I assume you have choosed option to save translation data in loco translate folder…
- April 24, 2020 at 7:46 pm #122581
Keymaster@Henriette please install and use Loco Translate as suggested by @SebastianFloKa.
Thank You! - April 24, 2020 at 8:26 pm #122594
Henriette
ParticipantAh! Now I see! I am already using Loco Translate but I didn’t know I had to sync after update to get the strings.
Before sync I could not find them.
This was my first update of Marketplace.
Is this always the case that as soon as you sync the .PO file after an update new language strings comes available?Anyway…thank you very much! I LOVE Local Pickup option!
- May 10, 2020 at 11:30 pm #129307
PATRICIA MARTINEZ PEREZ
ParticipantHello, where can I see the options for store pickup? Thank you
- May 11, 2020 at 2:26 pm #129504
