Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › I FOUND A BUG…PLEASE READ THIS
- This topic has 15 replies, 3 voices, and was last updated 6 years, 6 months ago by
- February 3, 2020 at 10:39 pm #105229
ing.rapparini
ParticipantIf I disable “Live Chat” from SETTINGS–>MODULES
this will broke every other settings I try to update…for example “Inquiry settings”…ecc…
- February 5, 2020 at 6:51 pm #105562
KeymasterHello
Thanks for getting in touch with us. I tried your process flow but failed to replicate the issue.
Can you please check in Google Chrome Browser console, is there any JavaScript error happening to the site or not! (What is browser console – https://support.airtable.com/hc/en-us/articles/232313848-How-to-open-the-developer-console)
Thanks - February 6, 2020 at 10:38 am #105668
MemberWhat is your WCFM Ultimate version?
- February 6, 2020 at 12:48 pm #105707
ing.rapparini
Participantyes sure… I noticed other errors if I enable/disable something in SETTINGS–>MODULES…
- February 6, 2020 at 12:51 pm #105709
ing.rapparini
ParticipantThis reply has been marked as private. - February 6, 2020 at 12:52 pm #105710
ing.rapparini
ParticipantFor example, you can try to modify something in “product custom validation”…save…refresh…and voilà,. NOTHING HAPPENED.
- February 6, 2020 at 5:59 pm #105862
ing.rapparini
Participantsdrang.com
- February 7, 2020 at 5:31 pm #106109
KeymasterThis reply has been marked as private. - February 9, 2020 at 7:45 pm #106317
ing.rapparini
ParticipantThis reply has been marked as private. - February 10, 2020 at 7:22 pm #106512
ing.rapparini
ParticipantThis reply has been marked as private. - February 13, 2020 at 7:02 pm #107020
ing.rapparini
ParticipantThis reply has been marked as private. - February 14, 2020 at 5:08 pm #107145
KeymasterHello,
It’s fixed now. Though, the problem was not related to WCFM or any other plugin. Max Input Vars in your host was set to 1000, which was limiting $_POST global variable size. Currently it is set to 4000.
- The topic ‘I FOUND A BUG…PLEASE READ THIS’ is closed to new replies.
